850 sqft. Addition to house - Rockin' and Rollin'
/ 850 sqft. Addition to house - Rockin' and Rollin' #21
Bet your heat index has been hovering around 100 doing this framing.
/ 850 sqft. Addition to house - Rockin' and Rollin' #22
Nice project, moving along quickly. Your doing a lot of the work yourself? I assume frost is a non issue there? The footings look shallow compared to what they would be here. Continued good luck!👍
Yessir! Most days. When you're out out working in it everyday and you take the necessary precautions it is manageable. But by the end of the week I am whooped.
Thank you! It is definitely going well. Up to this point I have done everything except lay the block.
Technically the bottom of the footing should be 12" deep and most of them are except one little spot that needs to get backfilled some, then it will be 12" deep.. But no, we do not have issues with frost. If the ground ever froze 12" deep here I would be really shocked. I have seen ice on standing water only a handful of times in 25 years of living here.
2017 John Deere 8245R (A60462)
2017 John Deere...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
Topcat SSSCR72 (A60463)
Topcat SSSCR72...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
