What Caused This Wood Deck Failure?
/ What Caused This Wood Deck Failure?
At the risk of derailing the OP's thread, try one of these traps:
Swat one and put it in the jar as bait. Hang it in a sunny area near where the bees are active.
BD, feel free to "derail". Those things are eating the rafters of one of my barns too, so this is of interest to me. How does the trap work?
/ What Caused This Wood Deck Failure? #102
2, are you saying Lowe's was able to order siding to match yours, even though it was not a brand they carry? Or, just that they were able to match the color with a brand that they do carry?
Looking at their web site, it looks like they carry 5 brands, plus something called "unbranded". But they don't list "Alside" which is my brand. Perhaps I'm making too big a deal out of this, maybe siding is siding... I know even less about siding than I do about treated wood.
I do know this, if I can't get pretty close to an exact match, it's going to bug me. A lot.
Not sure where in MO you are, but Alside has a few distributors in the State.
Alex, thanks for that. The place in "North Kansas City" is closest, but that one looks like just a warehouse, not someplace you could actually walk in and buy something (although, that's just going by what I see on Google Street View). They also listed a dealer on the south side of town, which I actually visited, but he said the closest one of their stores that sells Alside is on the Kansas side.
All academic for now at least because it turned out I had enough extra in the stash to do the job. Would be good to know where to go if I ever need any more though. Me being me, I'd kind of like to just go buy some more to have "in stock" anyway, just in case, and before they stop making it....
/ What Caused This Wood Deck Failure? #104
Replaced the missing siding yesterday and this morning the deck went bye-bye in the dumpster. Next will build a little more permanent stair/landing. Going to try to re-use some of the good pieces of lumber reclaimed from the old deck (yes, there actually were a few, mostly deck boards and guardrail pieces).
Discovered another occupation I don't want to be - siding installer...
Looks good
Looks good
Thanks. I was able to cheat because I still had all the original pieces, including the insulation and starter strip. So, I just lined up the old nail holes and didn't have to do any leveling. Just had to cut a couple of new pieces to length and re-use the old ones.
/ What Caused This Wood Deck Failure? #106
They work very well. The bees are drawn into one of the holes and see light below. The light attracts them and they can't find their way out. I have to empty that jar twice a season. In three seasons, I have almost eliminated them all.
As I said, the trick is to place it in a sunny area near where they are active. A dead bee in the jar is also good bait.
They check in, but don't check out.
/ What Caused This Wood Deck Failure? #108
I'm redecking a deck I built 32 years ago with "old school" pressure treated. Other than deck boards the joists and beams are still in good shape. Even the posts buried in the ground and concrete (allowed by code back then) still seem solid.
/ What Caused This Wood Deck Failure? #109
I have several of these. Problem is, they fill up in no time. I have found it works best for me to spray the wood with high yield 38
/ What Caused This Wood Deck Failure? #110
Yeah, they can be a pain to empty if they're not in a convenient location. I can easily reach mine from my elevated deck.
/ What Caused This Wood Deck Failure? #111
You might do an image search for building deck steps just to see if there's some design that someone has done that appeals to you.
Have been doing that. However, the design parameters are pretty much set. The stair can't turn left coming out the door, because the storm door is hinged on that side and because there is a window well where the steps would be.
I don't want to come straight out with it because that would take up too much room in the middle of the slab. Also, there is large amount of slope from the house to the middle of the slab that I don't want to deal with.
So, I've decided to do a 42" x 42" landing at the door with the stair extending parallel to the wall under the windows. This takes up the least amount of space, while also keeps me from dealing with too much slope.
Just because I'm lazy and because it's still in pretty good shape, I'm going to re-use the old stair from the deck that you see in the picture, just tack it onto the side of the landing. So, actually, the landing will be 42" x 53" because the top step is the same height as the landing.
So, the only decision left is what to do about a guardrail/handrail. The stair is short enough that a true handrail and guardrail are not required, so I'm going to just put 4 x 4's at the corners with a 2 x 6 on top and maybe an intermediate 2 x 4. Then, let it all weather for a while and use up some of the old TWP pecan deck stain I have left over from the deck to finish it up.
/ What Caused This Wood Deck Failure? #113
Long term, you'll want to be sure that water splashing off the platform and stairs can't rot your sheating.
Speaking of water, here's that swale doing it's job on Monday morning. Notice the water squirting out of the rock wall on the right side of the picture. We had a crazy rainstorm going on for hours. More rain than I've ever seen at one time. Even had ruts in the gravel drive to repair and that's never happened in the 18 years we've been here.
Even had a pond in the front yard for awhile when the culvert under the drive clogged up from debris...
/ What Caused This Wood Deck Failure? #115
One thing I like about having the patio stop where it is, I can get through there with my ZT mower now. Ever since 2011, I have not been able to do that.
You know, decks and patios don't have to be square or rectangular. You could cut a bevel/angle corner there to allow passage.
Now you're going and getting all creative on me....;)
Funny thing is, you wouldn't believe how long it took me to a.) decide to build a deck instead of expand the patio and b.) make the deck a rectangle.
I could never make it as an architect.
/ What Caused This Wood Deck Failure? #117
What is the story of your rock wall? Those are substantial cut stones. Usually don't see those around here unless they are mortared in place for a house foundation or in some instances have seen them around private cemeteries.
It's kind of a long and weird story. Even though we are on 6 acres, the previous owner wanted the house close to the property line on that side because her parents house was next door (and she presumably wanted to be able to take care of them in their old age). Because it is closer to the property line than in needs to be from a construction standpoint, they needed to deal with the uphill slope via a terrace/retaining walls.
Apparently, they must have had access to a LARGE amount of this quarried stone because they have this stuff elsewhere on the property too. There is a stone walkway leading from the patio down to the driveway on the other end of the house and the same stuff surrounding the evaporation pond for our private sewage disposal system. Plus, there is a pile of them in the woods that could be used for projects someday (like maybe a fire pit).
Most of the rocks are bigger than the ones in the wall, like 1000# or so.
Anyway the terraces look kind of cool, but are a pain in the neck to mow, so mulch and ground cover may be in order for that whole area someday...
Another round of big storms last night. Water from the swale is causing me to fix a washout in the driveway for the 2nd time this week (and 2nd time ever).
I am not going to complain because I would rather have this than the drought we've had the last couple of years.
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
