John Deere 390 Flail mower
/ John Deere 390 Flail mower #1
Lineman North Florida
Elite Member
LaCrosse Florida
Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
I'm looking at one on an auction site and am thinking about bidding on it but don't know anything about this model and really very little about flail mowers, does anyone have any experience with a John Deere 390 flail? it's centered not offset. Thanks.
/ John Deere 390 Flail mower #2
My father had a JD25A finish flail mower which is a 7 foot finish flail that he used to
maintain 12 acres of reclaimed pasture land to a 2 inch cut mowing 4 acre blocks once
every 2 weeks using a Ford Jubilee.
The JD390 is an $8,000.00+- finish flail mower, so if you can win the bid on it, you
will have a flail mower that will outlive your current tractor as long as it is taken care
of and you can mow heavy tall brush easily it will just take you a little longer and the
clippings will dissolve in the soil.
This model finish flail mower is not very old either so it would be worth buying.
Thanks for the response, this one cuts 7' 6" and according to the auction it's a 2016, we will see.
Update, well I won the bid after tax and buyers fee it was a little under
$600.00, we will see if it's any good.
/ John Deere 390 Flail mower #5
Please post some pictures of it when you have time to send them.
I will but I can't pick it up until next week, but when I get it I will definitely post some pictures.
Here are a few pictures of it, I didn't have a lot of time this afternoon but I tested it and it seems to cut fairly well.
/ John Deere 390 Flail mower #8
I want to welcome you as the newest resident member of the
Flail Mower Nations from the State of Florida.
Happy mowing
Happy mowing
I'm going to work a job tomorrow and I am going to try it, probably a little trial and error learning how set it up and adjust for a good cut.
/ John Deere 390 Flail mower #11
Hello and good evening, I wanted to let you know that you
need to adjust the top link correctly for it to work effortlessly
and also have a good cut.
Please use a small bubble level placing it on the guard over the
universal joint to adjust the top link to level the flail mower from
front to back with the bubble facing you.
The top link must be extended outward to level the gearbox and
by doing this the flail mower will not scalp.
The flail mower is now at its lowest cutting height PROVIDED the
top link is extended and the gear box cover is level.
Please block up the sides of the flail mower before you adjust the
rear roller as described below:
To raise the cutting height you loosen the 2 lower bolts and remove
the 2 top bolts holding the rear roller in place and set the rear roller
bolts in the next to last hole for the adjustment and you will have a
much better cut.
Please use a hydraulic car jack if you have one to adjust the rear roller
as it is heavy.
Leon
much better cut.
as it is heavy.
Leon
Thanks for the information, that will help me out.
LNF, that might just be the best 600 bucks you've ever spent. The deal that I got on mine was the best deal on one until you bought that one. That's a flail of a deal.
Yeah, after 10% buyers premium and 7% sales tax it was $580.50, sometimes you can get a deal at an auction other times if there are a bunch of dealers , the price get's run up as high as a new one.
Well I did a job with it today and thought it cut pretty good, did 10 acres and it has already paid for itself, I'm sure as I learn more about setting it up and experimenting a little I can fine tune it, looking at it this afternoon it looks like to me these l shaped blades can be flipped to use the other side to cut with, I'm learning as I go.
/ John Deere 390 Flail mower #16
Yes they can be turned, and resharpened too, great winter project
/ John Deere 390 Flail mower #17
I don't have the same brand of flail as you (Mott & New Holland) but on mine I will flip the knives and then replace them. I tried sharpening a set one time and it was a tiresome process verses the relatively reasonable cost of just putting on a new set from Flail Masters.
I keep a spare set on hand for each of my flails, just in case.
Thanks for the info, looking under it and counting yesterday there appears to be 3 rows with 14 attachment points on each row totaling 42 with 2 blades each so that would be 84 individual blades to sharpen, so I am definitely going to flip them first before replacing.
/ John Deere 390 Flail mower #19
Your John Deere 390 flail mower is equipped with a 3 row finish mower rotor with side slicer knives.
The knives can be sharpened with a wet well grinder easily to prevent them from losing the blade
temper and hardness.
I have a wet well grinder and the same side slicer knives I bought in 1992 to replace the original side
slicer knives that is came with in 1982.
If you are sure you simply want to replace them you can but sharpening them is not difficult.
They become encrusted with grass dust and dirt and that affects the quality of cut and they need
to be soaked in hot water and washed and scrubbed with a steel brush in Dawn Dish Soap and this can be done in the off
season.
If the opposite side is sharp they have never been flipped so you can do that but you should plan on
having a replacement hanger strap and a new nut, bolt and washer for each mounting station.
If you have access to a steam jenny all the better as you can remove all the grass dust and dirt under
the flail mowers rotor shroud and the rear roller and the bolts as mower does create static electricity
and the grass dust will stick to everything everywhere.
Leon
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A67147)
2012 FREIGHTLINER...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2019 CRUISE CAR INC ENCLOSED UTILITY CARGO CAR (A67148)
2019 CRUISE CAR...
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
1996 Chevrolet Astro Cargo Van (A64194)
1996 Chevrolet...
