What Caused This Wood Deck Failure?
   / What Caused This Wood Deck Failure? #81
California climate may have helped? I've heard your cars don't rust out.
unless there are some underground utilities to contend with, one thing I'd do is to add an underground drain to the gutter downspout so rainwater isn't being dumped out to just run back under your house.
Mild climate here… few with A/C and older homes had heaters optional.
Decks still fail but the old Green Treated Wood has exceeded my expectations.
The replacement stuff sold when the green pulled from the consumer market simply a waste of time and money.
At the folks home the deck circa 1965 is heavy galvanized steel girders supporting concrete with inset 12x12 tile and railings of heavy galvanized steel.
60 years and no issues.
Couldn’t hazard a guess what it what cost today.
The original owner had a steel fabrication company that built bridges and pedestrian walks around marinas among other things.
   / What Caused This Wood Deck Failure? #82
I can remember a treated wood called Wolmanized (sp?) but I think it had cyanide in it or some other toxic substance. That seemed to be the downfall of the good treated lumber.
   / What Caused This Wood Deck Failure? #83
I would say - trapped moisture. I have two small decks - 10x16. Both are raised well off the ground - 40 inches or more.. Both were built along with the house in 1982. They are as solid as the day they were built. Neither has any type of skirting.
There is 3/8 inch gap between each of the deck boards. The local winds can blow up thru the decking.
Another factor - our area is semi-arid. Annual rainfall ~ 12 inches.
   / What Caused This Wood Deck Failure? #84
It was about 20 years ago when they started f ing with the proven treatment chemistry. (CCA)
IIRC the first rendition was corrosive to common fasteners and aluminum flashing. I'm not sure how many changes since then but I don't think the current version is (or maybe as) that was.
In my little bit of checking I was told or read that "timbers" were still allowed to use CCA. What dimension constitutes a timber I don't know.
   / What Caused This Wood Deck Failure? #85
Yes, it is banned in many areas due to the hexavalent chromium in it (close to 50%). ("CCA-C")
There was another commonly used product that was pentachlorophenol. Also not very healthy for humans, and quite persistent.
All the best,
Peter
   / What Caused This Wood Deck Failure? #86
I’m surprised that your annual precipitation is so low. Typically ponderosa pine grows in areas with 18-30” annual precipitation. Above 30” Douglas fir becomes dominant. Below 18” is typically woodland species like junipers.
   / What Caused This Wood Deck Failure? #87
Perhaps grey pine or stone pine?
   / What Caused This Wood Deck Failure? #88
Wolman is a company that is big in pressure treated wood. One of the first, I believe. Wolmanized was just their brand name for it. The industry reformulated all PT to get away from the arsenic compounds close to 20 yrs ago. It wasn't just them. They cranked up the amount of copper which costs a lot and was what made all the regular galvanized fasteners disappear in no time due to galvanic corrosion. Developments since then have allowed them to reduce the copper content quite a bit but it is still pretty corrosive thus the need for triple dipped galvanized or SS stuff.
There are still some arsenic based treatments available but they are specialized and not easy to get.
   / What Caused This Wood Deck Failure? #90
I doubt you actually did anything that caused it. Treated wood today just doesn't last. I'm finding yellow wood doesn't last as long as other brands of treated wood.
I have some yellow treated wood on my deck that has rotted, while treated wood of a different brand (from Lowes) is still good and it's right next to each other
   / What Caused This Wood Deck Failure? #91
Carpenter Bees seem to love the new treated wood while they avoided the older type. The deck joists I replaced a few years ago are riddled with their holes.
   / What Caused This Wood Deck Failure? #92
OK - I checked the average rain/snow water accumulation for the Spokane, WA area. It's - 16.93 inches. I'm somewhat less than that here. 2023 - 12.84 inches. I have a Davis Vantage Pro 2 to measure rain fall/snow conversion.
Still it's enough to grow the gigantic Ponderosa pines I have here.
   / What Caused This Wood Deck Failure? #93
You must have soils with great fertility and good water holding capacity. 17” is on the lower end of ponderosa pine growth needs. I would bet the decadal precipitation average is higher than 13”.
   / What Caused This Wood Deck Failure? #94
Have you ever considered extending your concrete deck towards the slope and building a retaining wall? You could have a nice raised garden or a flower bed on the edge of the retaining wall and you'd have enough area or a table and chairs. Just a thought vs spending money on something that might rot away again in a few years. The trade off would be that you once again have steps in a awkward place because the door placement isn't ideal for that deck. Just my thoughts.
   / What Caused This Wood Deck Failure? #95
I would have thought the concrete slab underneath would be somewhat of a moisture barrier?
With a layer of visqueen underneath it might be. It is amazing how much moisture can surface on concrete especially when it warms up - even with a layer of visqueen
   / What Caused This Wood Deck Failure? #96
Built this porch 20 years ago and there has been zero rot. It has lattice around the bottom now and railings were added 12 years ago when my son was born. We've probably stained it 3 times over the years. It's built over dirt and I'm sure the roof helps.
   / What Caused This Wood Deck Failure? #97
Runner's patio would be nice with a roof. Even if a roof isn't being added at this point, might think about making sure that any additional concrete has adequate footers to support posts for a roof if he decides to add one later.
   / What Caused This Wood Deck Failure? #98
That treated wood seems to attract those bees, while they don't seem to bother regular wood in my barn !
Replaced the missing siding yesterday and this morning the deck went bye-bye in the dumpster. Next will build a little more permanent stair/landing. Going to try to re-use some of the good pieces of lumber reclaimed from the old deck (yes, there actually were a few, mostly deck boards and guardrail pieces).
Discovered another occupation I don't want to be - siding installer...
   / What Caused This Wood Deck Failure? #100
At the risk of derailing the OP's thread, try one of these traps:
Swat one and put it in the jar as bait. Hang it in a sunny area near where the bees are active.
2019 CATERPILLAR 259D3 SKID STEER (A60429)
2019 CATERPILLAR...
2016 FREIGHTLINER CASCADIA SLEEPER (A59905)
2016 FREIGHTLINER...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2015 Chevrolet Tahoe, 192,897 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2015 Chevrolet...
2015 Bobcat S650 Skidsteer - Enclosed Cab - 5462 Hours (A56438)
2015 Bobcat S650...
Here are some similar links:
