Loader Repair vs replace bucket links
/ Repair vs replace bucket links #1
Husaberger
CA
L4740 HST, DK65S
My 2000 hr L4740 has seen some pretty heavy use and the bucket has a fair amount of slop
6 replacement links will cost me about $600
Has anyone out there repaired them?
060, 070, and 080 in the drawing
/ Repair vs replace bucket links #2
pins that connect those parts must be worn too? # 10 & 20
/ Repair vs replace bucket links #4
If you have your own machine shop and work after hours your time is "free". If you have to hire a machine shop to repair then $600 is probably cheaper and faster to buy replacements from K.
/ Repair vs replace bucket links #5
I've got the same issue. I replaced the 6 lowest pins on the FEL with no improvement. I bought the 6 link pieces and swapped them in a few weeks ago with no improvement, either. With everything apart it is easier to see that there is significant slop around the bucket curl rod eye, which has a $160 bushing that I have not replaced, yet. There is also significant slop at the barrel end eye that does not have a bushing.
My next step is to remove the rod eye and barrel pins and measure the dimensions to see if they line up with the specs from this (incorrect) table. The table is from an L35, but the dimensions are similar/identical to the LA854, and the LA854/L4740 WSMs do not have a similar table available.
From the preliminary measurements I've taken so far the LA854 appear to be within tolerance, a tolerance that seems to be quite loose... 🤷‍♂️
/ Repair vs replace bucket links #6
What I did was I ordered ONE new link from my dealer and plotted it and cut a complete set on my CNC plasma table and then made my own pins from bar stock but instead of counterboring the pins and recessing the fittings (which I don't like anyway because all they do is fill up with crud), I changed the grease point to the weldment between the linkages. I did pay a restock fee to return the new but not used dog bone linkage to Kubota. Don't need it and I have the plot in my computer now. After I cut them, I added a welded on boss on each one I cut from pipe stock. That distributes the load much better and mitigates the pin and dog bone wear appreciably. In fact, my dealer wants me to cut a couple sets for him as well. I can purchase the sheet stock and cut them for about 1/4th of what Kubota wants for them and I'm sure they are subbing that out to someone with a CNC plasma table anyway. They aren't making them in house.
When I examined the Kubota part carefully, I could see not only the plasma cut line but the piercing point as well.
Not rocket science, just copying a part they have subbed out.
/ Repair vs replace bucket links #7
Construction type hoes and loaders will all have bushings installed that can be renewed. Light duty units will not.
/ Repair vs replace bucket links #8
Very fair statement however, I own and operate a short run machine and welding shop so I have all the necessary tools and machines to make my own and yes, my time is my own so long as the machines aren't being used for customer work. Far as the rod end bushings are concerned, I would make them from 660 CA oil impregnated bar stock which is easily replaceable and easily machined as well. Steel bushings bearing on steel pins will always wear in an oval manner, depending on how the load is applied over time. I'm sure it's not profitable for Kubota or any other non construction orientated manufacturer of tractors, backhoe's or front loaders to supply their units with replaceable bushings. Much easier and less time consuming to just make them steel on steel.
My take is on any non industrial application, just keep them well greased with a high quality synthetic EP grease. Don't Kubota recommend greasing all the pivot points every 10 working hours? I'd be greasing them every time I used them actually and I do on my loaders anyway. Grease is cheap, rebuilding the linkages isn't.
Welp. I bought all the links
Will report back if any improvement
What's the part no for the $160 bushing JIC?
/ Repair vs replace bucket links #13
7J275-64510, NLA from Messicks but Coleman has 2-5 day lead time. Note that it says it is for an LA844, so no guarantee it will fit properly.
Yes, it should be fancy, alas it will likely just be a soft sleeve. I do plan to press one of mine out to confirm ID and OD, in case some handy person would be inclined to turn me one or two from a 660 rod/tube. Or, if we're really lucky one can be found at McMaster.
This also doesn't address the play at the bucket cylinder tube end, however.
/ Repair vs replace bucket links #14
Been getting replacement parts I need from Coleman's right along. Their shipping is less than Messicks (unless I can order what I need from my dealer) and they ship very promptly as well. Some stuff I really cannot make in the shop at any savings. The dog bones (parallel linkages) are a different story however as well as the bushings and pivot pins. Steel, in general has become quite expensive today and alloys like stainless and aluminum is even more. I do have a pretty large inventory on hand of bar stock and ground bar in mild steel and stainless. Thank the lord for that. Until something gives with the economy, I dread buying any.
The plot thickens
7J275-64510 discontinued by Kubota although some dealers still have stock
It's used in the following FELs
7J275-64510 has associated part number 116060040 which may be the manufacturer's number but web search results in no additional information
Looks like we either need to bite the bullet and pay $300+ for a pair of $5 parts, have a set machined which entails one of us obtaining dimensions, or live with bucket slop
/ Repair vs replace bucket links #16
OK, confirmed some measurements:
OD of bushing is 1.500 +/-0.003"
OD of a new pin 7 for this link is 1.185"
ID of rod eye is 1.497"
I fumbled around with this set to get the bushing pushed out about 1/2" to measure it and the rod eye: Powerbuilt Ball and U Joint Service Set, 23 Piece. The bushing would jump about every 1/2 turn of the wrench, so it was in there good.
As of right now I'm looking at getting 13" of this and shipping it to my brother with a lathe. OD will need to be turned down and the ID will need to be increased to an appropriate dimension, likely 1.190 to 1.195". If all goes well, we should be able to generate 4 bushings at 2.20-2.25" each, with material left over.
In other news, as noted previously, the cylinder barrel pin also has some play, note the pin does not rotate in the weldments as it is bolted on the far side.
/ Repair vs replace bucket links #17
Sounds like a plan. Once your brother gets set up he can probably make coffee can full of those bushings in not much more time than making four for you. Especially so when the ID and OD are already so close.
It's nice to have a little bit of machine shop capability at home. Even nicer when retired, as it gives old friends an excuse to stop by, use the tools, and share projects.
rScotty
2019 Chevrolet Express Box Van, VIN # 1HA3GTCG9KN007839 (A61165)
2019 Chevrolet...
UNUSED WOLVERINE SB72-72" ROCK BKT (A62131)
UNUSED WOLVERINE...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
