Trailer hubs shedding grease caps
   / Trailer hubs shedding grease caps #11
And like others in this thread, I have simply drilled a small hole in the cap to relieve pressure. MMC
yes to above, a weep vent
   / Trailer hubs shedding grease caps #12
I've had grease caps that seemed a little springy when installing them, and wanting to pop back off, presumably due to air trapped between the cap and the hub.
I don't remember the solution though. :(
One thing I did determine is that you don't need too much grease. So, grease needs to be where the bearings are. However, you don't need to fill the dust cap with grease. That does nothing, and only adds to friction. If you fill the cap with grease, drive for 6 months, and inspect again, you'll see the same cap full of grease. The nut also doesn't need grease on the outside.
Just keep the grease where the bearings are. Lots of grease around the bearings.
I would not drill a vent hole in the caps. While perhaps not the worst thing, it does provide a place for water ingress.
If you get some bearing buddies, they fit tight, and give you a little extra headspace. They likely would fix the problem, even if you don't actually use them to pack the grease.
   / Trailer hubs shedding grease caps #13
may not look pretty, but my caps never fit some of my trailers well, I simply wrapped electrical tape around the hub and the cap, and the issue never came back.
Something is wrong with the bearings on that hub causing a spike in temperature to pop the caps over and over.
Well I have an IR sensor gun that I check hub temps every time I stop. I do this on the RV as well as all three equipment trailers. I also have the Tireminder sensors for tire temps and pressure readings real time in cab. Tire air pressure which would be directly effected by hub and wheel temps as well as the tires never got above 60 deg F. The IR hub temps never rose above 94.7 degree F and that was not on the effected hub but the axle behind it.
I think ruffdog could be onto something here. Check bearing temperature after several miles, and see if it's abnormally high. If not, the only explanation I can imagine is that there's just not enough air space (eg. too much grease), causing abnormally high pressure for the small expected temperature rise.
OP didn't state if these were EZ Lube, Bearing Buddy, or any other specialized system, so guessing just regular old hand-packed bearings. EZ Lube usually has rubber caps that fit inside the stamped steel hammer-ons, and bearing buddies usually have rubber condoms that go over a machined steel hammer-on.
Regular old stamped steel grease caps aren't vented. Usually not an issue.
They are EZ lube hubs with the rubber center caps that go into the metal grease/dust caps. If it was an air pressure effect it would blow the other rubber plugs out long before the metal caps would be shed.
I think this is a bit more common than some think. While it is possible to get bearings too tight and experience heat build-up, lubricants do expand as they get warmer and with no place to go except around seals and the cap, they can push the cap off. And like others in this thread, I have simply drilled a small hole in the cap to relieve pressure. Perhaps a short test drive, reach down and feel the hubs on both sides. If one is much hotter than the other, pull it apart and see what the real problem is. If the same, try the 1/16" hole approach. Cheap solution.
The hub temps are within 2-3 degree F of each other whether it is a 1 hour drive or a 5 hour drive
   / Trailer hubs shedding grease caps #16
Agreed. This is weird. Just to be clear, you're saying these are EZ Lubes, with the usual rubber center plug in the cap, but you're losing the steel stamped housings that hold the rubber caps?
I've owned a lot of EZ Lube hubs, and I've never seen anything like that. The rubber plugs are leaky enough that there's no real chance to build pressure.
For anyone who doesn't know what we're talking about, look up EZ Lube hubs. They're a great rig, and they're already vented by means of a rubber cap with a grommet ring, which never fits air-tight. They're also unlike normal hubs, in that you end up totally filling the cavity with grease after a few maintenance cycles, as the new grease pushes the old grease out into that cap space, and eventually out around the grease gun fitting.
   / Trailer hubs shedding grease caps #17
Yes, a mystery for sure since they are that style.
   / Trailer hubs shedding grease caps #18
I've lost the grease cups off of my Haulin trailer (little 8x5.70 tires). I think I probably scraped them off on bollards. Whether that is possible in the OP's case would depend on whether the grease caps are wider than the tires.
I had hunted for replacement caps at auto parts stores and they didn't have any. I think trailer caps may be different than auto caps. So, soda cans and electrical tape was it. I've had those on the trailer for an awfully long time, and they've served me well.
   / Trailer hubs shedding grease caps #19
Totally different subject, but back in the 1980's, the OD of Bearing Buddies was an exact match for the ID of a 12 oz. Coca Cola can. Saltwater boaters used to hose clamp fresh soda cans over their bearing buddies each season, easily replaceable dirt and water shield, sort of belt + suspenders.
Totally unnecessary on bearing buddies, maybe even counterproductive given how they work. All I can guess is that stainless steel wasn't so common back then, so maybe the Buddies themselves corroded in salt water, and this was a way to keep them dry.
I have the worst of both worlds, in that I have EZ Lubes on one of my boat trailers, and Bearing Buddies on my landscape trailer. I'm not sure why trailer manufacturers routinely and consistently make such terrible choices in their bearing selection. Bearing Buddies may be the best thing on earth for boat trailers, but absolutely suck for anything with brakes that's not getting dunked in the water. Likewise, EZ Lubes are great for everything except boat trailers.
2018 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2018 INTERNATIONAL...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
EZ-GO GOLF CART (A56859)
EZ-GO GOLF CART...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
SKID STEER ATTACHMENT (A58214)
SKID STEER...
