Trailer hubs shedding grease caps
/ Trailer hubs shedding grease caps #1
Silvic
Gold Member
West of no-where
I recently replaced the brakes, wheel bearings and races on my equipment trailer. Took it out for test run of about 30 miles and everything went fine.
Left on a 1000 mile round trip. About half way through I noticed that one of the grease/dust caps on the hubs had departed the trailer. Of course there was grease all over the wheel.
When I got to my destination I purchased some spare grease/dust caps, cleaned up the wheel put more grease in the bearings and reset the cap. It was very tight, more so than the used ones that I had re-installed after the earlier mx. Had to use a big mallet to get it to seat properly and was happy. Somewhere between 30 miles and 170 miles later there was no grease/dust cap on the same hub. Put another cap on the hub and more grease in the bearings. After 49 miles it was missing again. Three caps in 750 miles and they fit really tight.
Called etrailer.com as I got the bearings and brakes from them to ask if they had heard of the issue. Pretty much they said no. After that I googled the issue and found several Q&A on etrailer.com site where the question had been asked before. In every case the answer was the cap must not have been fully seated in the hub.
I KNOW that the cap was seated in the hub fully. There is no reason to suspect that the hub ID has been compromised due to the tight fit of the cap on installation but is a possibility.
I have considered using RTV to try to seal and hold the cap in the hub but don't really think it will work.
The hub is fine otherwise and don't really want to get a new hub but may have to do so.
Any ideas as to how to stop this. It is not good and makes one heck of a mess.
/ Trailer hubs shedding grease caps #2
Are we talking about the metal caps coming out or just the rubber dust covers that are used on greaseable axle trailers. I suspect that you have too much grease behind the caps and when the grease gets warm it expands to the point that it is pushing the rubber caps out if your trailer has those.
/ Trailer hubs shedding grease caps #3
He used a mallet to seat the caps.
Op, I had this issue on a trailer several years ago, they were the all metal caps, no rubber plug, so no vent. I ended up drilling a 1/16 hole for a vent and no more issues. I suspect they sealed too tight and the heat/pressure buildup, pushed them off.
/ Trailer hubs shedding grease caps #4
I agree. Sounds like the new caps are not vented or the grease is plugging the vent.
/ Trailer hubs shedding grease caps #5
If he replaced the cap on the road with the axle already warm it shouldn't be a vent issue but anything is possible.
/ Trailer hubs shedding grease caps #6
The grease is still cool when applied.
/ Trailer hubs shedding grease caps #8
I think ruffdog could be onto something here. Check bearing temperature after several miles, and see if it's abnormally high. If not, the only explanation I can imagine is that there's just not enough air space (eg. too much grease), causing abnormally high pressure for the small expected temperature rise.
OP didn't state if these were EZ Lube, Bearing Buddy, or any other specialized system, so guessing just regular old hand-packed bearings. EZ Lube usually has rubber caps that fit inside the stamped steel hammer-ons, and bearing buddies usually have rubber condoms that go over a machined steel hammer-on.
Regular old stamped steel grease caps aren't vented. Usually not an issue.
/ Trailer hubs shedding grease caps #9
Applied hot or cold, the hydrocarbons in the grease continually form gases. It's just normal "hydrocarbon cracking" and happens as long chain molecules break into shorter and shorter ones - plus gases. It speeds up when things get hot. That's how a cracking tower works.... and incidentally how grease forms oils for lubrication. .
A lot of old axles didn't have inner grease seals, but modern ones do. They seal better, too. Either the hubs or the caps need to be vented. A one way vent will keep water out.
rScotty
/ Trailer hubs shedding grease caps #10
I think this is a bit more common than some think. While it is possible to get bearings too tight and experience heat build-up, lubricants do expand as they get warmer and with no place to go except around seals and the cap, they can push the cap off. And like others in this thread, I have simply drilled a small hole in the cap to relieve pressure. Perhaps a short test drive, reach down and feel the hubs on both sides. If one is much hotter than the other, pull it apart and see what the real problem is. If the same, try the 1/16" hole approach. Cheap solution.
/ Trailer hubs shedding grease caps #11
And like others in this thread, I have simply drilled a small hole in the cap to relieve pressure. MMC
yes to above, a weep vent
/ Trailer hubs shedding grease caps #12
I've had grease caps that seemed a little springy when installing them, and wanting to pop back off, presumably due to air trapped between the cap and the hub.
I don't remember the solution though. :(
One thing I did determine is that you don't need too much grease. So, grease needs to be where the bearings are. However, you don't need to fill the dust cap with grease. That does nothing, and only adds to friction. If you fill the cap with grease, drive for 6 months, and inspect again, you'll see the same cap full of grease. The nut also doesn't need grease on the outside.
Just keep the grease where the bearings are. Lots of grease around the bearings.
I would not drill a vent hole in the caps. While perhaps not the worst thing, it does provide a place for water ingress.
If you get some bearing buddies, they fit tight, and give you a little extra headspace. They likely would fix the problem, even if you don't actually use them to pack the grease.
/ Trailer hubs shedding grease caps #13
may not look pretty, but my caps never fit some of my trailers well, I simply wrapped electrical tape around the hub and the cap, and the issue never came back.
Something is wrong with the bearings on that hub causing a spike in temperature to pop the caps over and over.
Well I have an IR sensor gun that I check hub temps every time I stop. I do this on the RV as well as all three equipment trailers. I also have the Tireminder sensors for tire temps and pressure readings real time in cab. Tire air pressure which would be directly effected by hub and wheel temps as well as the tires never got above 60 deg F. The IR hub temps never rose above 94.7 degree F and that was not on the effected hub but the axle behind it.
They are EZ lube hubs with the rubber center caps that go into the metal grease/dust caps. If it was an air pressure effect it would blow the other rubber plugs out long before the metal caps would be shed.
The hub temps are within 2-3 degree F of each other whether it is a 1 hour drive or a 5 hour drive
/ Trailer hubs shedding grease caps #16
Agreed. This is weird. Just to be clear, you're saying these are EZ Lubes, with the usual rubber center plug in the cap, but you're losing the steel stamped housings that hold the rubber caps?
I've owned a lot of EZ Lube hubs, and I've never seen anything like that. The rubber plugs are leaky enough that there's no real chance to build pressure.
For anyone who doesn't know what we're talking about, look up EZ Lube hubs. They're a great rig, and they're already vented by means of a rubber cap with a grommet ring, which never fits air-tight. They're also unlike normal hubs, in that you end up totally filling the cavity with grease after a few maintenance cycles, as the new grease pushes the old grease out into that cap space, and eventually out around the grease gun fitting.
/ Trailer hubs shedding grease caps #17
Yes, a mystery for sure since they are that style.
/ Trailer hubs shedding grease caps #18
I've lost the grease cups off of my Haulin trailer (little 8x5.70 tires). I think I probably scraped them off on bollards. Whether that is possible in the OP's case would depend on whether the grease caps are wider than the tires.
I had hunted for replacement caps at auto parts stores and they didn't have any. I think trailer caps may be different than auto caps. So, soda cans and electrical tape was it. I've had those on the trailer for an awfully long time, and they've served me well.
/ Trailer hubs shedding grease caps #19
Totally different subject, but back in the 1980's, the OD of Bearing Buddies was an exact match for the ID of a 12 oz. Coca Cola can. Saltwater boaters used to hose clamp fresh soda cans over their bearing buddies each season, easily replaceable dirt and water shield, sort of belt + suspenders.
Totally unnecessary on bearing buddies, maybe even counterproductive given how they work. All I can guess is that stainless steel wasn't so common back then, so maybe the Buddies themselves corroded in salt water, and this was a way to keep them dry.
I have the worst of both worlds, in that I have EZ Lubes on one of my boat trailers, and Bearing Buddies on my landscape trailer. I'm not sure why trailer manufacturers routinely and consistently make such terrible choices in their bearing selection. Bearing Buddies may be the best thing on earth for boat trailers, but absolutely suck for anything with brakes that's not getting dunked in the water. Likewise, EZ Lubes are great for everything except boat trailers.
