Bending my box blade hitch, please help!
/ Bending my box blade hitch, please help! #11
There are a few ways you could beef that up through welding. Replace the bent plate with something much thicker, or add another plate in addition after bending back, Extend the bottom horizontal plate closer to the pin, add a horizontal plate to the top, put a gusset on the bottom of that outer plate underneath the pin.
/ Bending my box blade hitch, please help! #12
That bend is caused by that connection being forced forwards into your tractor’s upper link.
Your scarifiers are on the front leading edge of your box blade.
When you hit something substantial underground with them, like a rock, or roots, the rearward force on the scarifiers pushes rearward on your lower links, and the force causes the upper box blade to try and rotate, forward, pushing on your upper link, causing it to bend.
If you don’t want to weld the two sides together, you could add tight fitting spacers to the sides of your upper link.
/ Bending my box blade hitch, please help! #13
They are the threaded type. I always thought they were designed to be pulled against(tension), not pushed against(compressed). Im not saying you're wrong, Im just having a hard time understanding how that would help?
You are correct that they pull no push. But they need some slop. If you set them tight at the bottom of the stroke they will get too wide at the top of the stroke. If you are able to watch the end of the links as the 3 point rises you will see them kind of arc out as it gets higher. I had the same thing with mine when I switched to the Pats hitch. The normal 3 point ends are smaller and have the rotating balls. The pats doesn't allow for much twist so it forces wider at the top.
/ Bending my box blade hitch, please help! #14
Or replace the pins with bolts, a couple of 7/8's bolts and nyloc nuts.
/ Bending my box blade hitch, please help! #17
Another vote for turning while under a load as the cause.
I managed to twist a scarfier shank doing that.
/ Bending my box blade hitch, please help! #18
Chris, can you confirm that you are lifting your box blade off the ground while making a turn?
It sure seems to me that if the box blade and its scarifiers are engaged into the ground and you make a turn some extreme lateral force is going to be placed on the plate in the picture which is bent.
/ Bending my box blade hitch, please help! #19
I guess it is a light duty box, but you would hope they would make the hitch points better than that... It looks like the designer was counting on sway adjusters that are inboard of the lower arms, but now almost all small tractors now have outboard sway control adjusters. A bolt and nut seems to be the easiest solution though, to get the both tabs on the box working together not to bend.
Yes, well that depends on what you consider a turn. I would say I change direction by less than 10 degrees.
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
