Sprayer recommendation
/ Sprayer recommendation #1
caprater1
John Deere
I'm needing a recommendation for a sprayer for a project. I'll be spraying an asphalt emulsion over milled asphalt as a tack coat. I used a garden pump sprayer (or tried to) and it was constantly getting clogged even without the filter/screen. The material is pretty thick but once reduced it's not too thick but it has something in it that's the texture of sand that settles to the bottom pretty quickly.
I was thinking about using a pump similar to what would be used in an RV. like the pic below. Any other recommendations?
/ Sprayer recommendation #2
That RV pump is made for water. I'd suggest one of the paint sprayers: Wagner or Graco. They're made for spraying thicker stuff. Get the biggest nozzle you can
I don't know if it's typical of the paint sprayers, but when using one in the past I've had them clog up with just paint. Dont they have filters/screens in the inlet?
If the area isn't huge, how about doing it with a stir, pour some and roll?
It's pretty big. About 250x12. I was really hoping to either roll or squeegee it on but it's on a good slope and it's also millings. So I took a 5gallon bucket and drilled holes in it, filled it and walked around quickly to spread it. The areas where I was turning around I wasn't fast enough and a lot ran off on the grass. I'm sure if I try to squeegee I'll have even more runoff plus I'll be picking gravel around with it.
Sorry I wasn't trying to shoot down your suggestions. I'm still open to more. In fact I'm planning to have at least 2-3 options available once I start the project so I can finish it either way.
There's gotta be a good solution. The reason I thought about the RV pump is because its a diaphragm pump, doesn't have a filter on the inlet, I can attach a garden hose end sprayer for even distribution, and I already have one.
Those seal and roller kits are all made for hot mix and hot applied asphalt. Since I'm doing this with recycled millings it won't work. But after I apply this tac coat and use my plate compactor on it, it'll look like paved road instead of gravel. They say it won't, but I have done part of my driveway already. No loose gravel there either. I'm impressed. It looks so much better and doesn't wash away on the slope with every rain.
/ Sprayer recommendation #7
Sounds like something fun to play around with. I've tried some unorthodox methods while looking for viable solutions to stuff like this. One time I whipped up a tank (used an old refrigerant jug) with an air connection to pressurize it and a siphon tube connected to a hose to force the product out of it. Maybe a little sketchy, but it worked OK. It was a pain to drag the compressor around to use it. With that, there was no pump to get clogged.
Regardless how you would get it to flow, you may want to try flattening a piece of tubing for the nozzle. Done that by inserting a flat piece of metal in the pipe while pounding on it so it didn't close off. A little playing around and you can get a fan pattern.
Now I think you're on to something. I have something similar to what you described. It's sold as a pump, but it's not really. Actually have several. One that's for bleeding brakes as a pusher, another as a siphon, and another to fill transmissions from under the car (the new ones without dipstick). Those are pretty small. With enough epoxy and duct tape I bet I can make one from a 5 gallon bucket. None of my refrigerant bottles are close enough to empty. I'm gonna make a fan sprayer like you mentioned. Thanks.
Cindy
/ Sprayer recommendation #9
Be sure to think it through before using a homebrew pressure vessel. I went with the refrigerant jug as a starting point because it was built for maybe 4X the pressure I could potentially apply to it. Still kinda winced when I charged it up:)
I couldn't think of all the possible defects created by welding / modifying it.
/ Sprayer recommendation #10
The last time I had mine coated, a guy backed down my driveway with a large tank in the bed of his pickup, a pump, wand like at a car wash and about 100 ft. of hose. IIRC, the tank had a heater and an agitator in it to keep the stuff from solidifying.
I'm sure that rig was not cheap but my point is that there are sprayers are made to do the job, the problem is finding someone close to home that has one.
He did my 16x170 driveway in about 10 minutes.
/ Sprayer recommendation #11
When I had my pole barn roofs painted, he had a great setup for spraying real thick asphalt type roofing paint. He said it was a used highway stripe sprayer.
Maybe you can find a local paint/sealer contractor and just pay 'em...
That's food for thought. This material doesn't require heat, but if I can figure a way to incorporate an agitator in with the sprayer that would be optimum.
I'm sure they sell these sprayers. I. Fact I've already looked at the ones sold to contractors for the job. But they are priced for doing this daily and providing cash flow.
This will likely be a project done once in 10 years so not gonna be able to spend that kind of $ on the sprayer and I couldn't find any for rent.
That's another good idea. I'm gonna watch the city and county auctions for one of these sprayers they are recommending.
Decommissioning not recommending.
2017 CATERPILLAR 305.5E2 CR EXCAVATOR (A63290)
2017 CATERPILLAR...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59910)
2019 CHEVROLET...
Hyundai Robex 55W-9A (A64047)
Hyundai Robex...
2021 TAKEUCHI TL12V2 SKID STEER (A63290)
2021 TAKEUCHI...
