What to Look for in Zero Turn Mower
/ What to Look for in Zero Turn Mower #1
lincmercguy
Colorado
JD 5105, JD 5055E
I think I'm going to upgrade from my riding mower that doesn't cut well. This would be to mow about 1.5ac, including around a lot of trees. I'm probably going to look at 48-54" deck width. I don't need commercial level, but would like something that is still dependable and serviceable.
There are a lot of brands and I know each brand has their various levels of machines. The ground isn't that smooth, so something with a bit of suspension would be nice. From what I've read, most recommend the Kawasaki engines for gas. No interest in electric.
/ What to Look for in Zero Turn Mower #2
Lots recommend the My ride Toro system. Make sure to get one with a decent transmission too.
I own a Simplicity Citation XT with the Full suspension. More expensive of course but the ride is excellent and doesn't beat your body up.
The my ride thing looks useful. TSC has one in stock here. What makes a decent transmission in these things?
/ What to Look for in Zero Turn Mower #4
The new Stihl ZT mowers have 4 wheel suspension. Make a big difference in ride comfort.
/ What to Look for in Zero Turn Mower #5
Look up the different models of transmissions used. I compared transmission and price, and avoided the low end homeowner units.
/ What to Look for in Zero Turn Mower #7
My Bad Boy Elite has a suspension. I have the just under 2 acres and lots of tress as well. The 54" deck works well for me, and I can cut in 45-60 minutes.
I came close to the Country Clipper with a joy stick but it did not have the suspension and a lighter gauge deck. I wish had gone with it as having a hand free to swat bugs is something I miss.
For the about the same $$, the Bad Boy is a better machine if lever steering is OK for you. But the joy stick is a neat.
I think a couple of ZT come with steering wheels as well.
/ What to Look for in Zero Turn Mower #8
Personally, I'd rather buy a used eXmark than a new low end unit, prices being equal. A commercial grade unit is going to have smoother hydro drive, a deck built like a tank that will literally last forever, and better ride quality. It'll also be more stable on inclines and will require less maintenance as the years go on.
We are now in our 8th season mowing with our E-series eXmark, doing 3 to 7 acres per week. Still on original spindles, hydro drive, tires, etc. etc. Can't kill these things.
/ What to Look for in Zero Turn Mower #9
I have a Scag zero turn that's a beast, but also a nightmare. All my problems have been with the electrical system. Too many safety switches, but I've also replaced every switch, the PTO generator, and even the key. After years of never knowing if it would start, and what I would have to replace to get it to start, I pulled every wire off of it and just installed the minimum that I needed for it to run. Now it starts every time, but I never know how long the belts will stay on when I turn them on. Some days, it's perfect. Other days, it throws a belt when I first try to use it, then it's fine the rest of the day. Yesterday it threw a belt on the third time I tried to start the blades. I grease the pullies about once a month and that seems to help. I greased it yesterday after putting the belts back on and it worked fine after that.
I really like the seat on the Scag, but I saw that the newer ones have a different seat, and it doesn't seem as nice.
I like the Kawasaki engine. It has plenty of power, but Scag does not include any details on the engine in their manuals. If I need a part for the motor, I have to go to a Kawasaki page and look up that engine for parts. I think it should be on the Scag website, but it's not.
The blades are easy to change. Just one bolt that holds the blades on. I can swap blades in just a few minutes.
I don't know what I would buy if I was buying today. From what I've heard, all the brands use the same electrical parts, and that's usually where all the issues are. They work great for a few years, then it's a never ending job of finding the safety switch that's not working so it will start.
/ What to Look for in Zero Turn Mower #10
Didn’t Simplicity drop that one when the Stihl line came out? Both of which are very similar to a Ferris IS series? And isn’t the BS parent dropping Simplicity altogether?
The Ferris 500S is a suspension system “residential mower” but only comes with a 25hp BS. Anything else (that I know of) is offered with just a suspension seat.
For 1.5 acres, wonder if OP has considered a stand-up?
/ What to Look for in Zero Turn Mower #11
Unfortunately even the Exmarks can be killed. 🥲
My BIL runs a fleet of them in his service, all well maintained. I work on them for him and usually around the 1200 hour mark Im doing motor work. He has both Kohlers and Kawasakis. The drives seem bulletproof though.
There is a big difference between running one all day everyday and homeowner use.
I wouldnt buy a used one, simply because most have been run commercially, but if I could afford it a new one would last a homeowner a long time.
/ What to Look for in Zero Turn Mower #12
I have heard that 1000 hours seem to be the watermark for Kawasaki engine "maintenance". What's the deal?
/ What to Look for in Zero Turn Mower #13
More like 1200 meter hours. They all require valve adjustments at that point anyway and all the Kawasaki and Kohler aluminum block engines will have a life expectancy of around 2000 meter hours before it's time to rebuild and all are gas guzzlers as well and why I traded mine in and went to a diesel. Hands down, way more efficient. The other thing that most owners seem to forget and that is, you really have to keep the deck underside clean, especially when wintering. Wadded up grass on the underside promotes corrosion and at some point will 'rust out' any deck, fabricated or stamped. I lean toward Hydro Gear transaxles over the rest, simply because they are serviceable and the more commercial ones will have built in oil filters and containment tanks for each drive unit.
Far as ride quality, none of them have a good ride, suspension or not. The short wheelbase is always a choppy ride, especially when mowing fast. The M60 Tank I just traded in on a Kubota F series diesel was a kidney buster. I have to say, I much prefer the steering wheel over the 'oars'. My wife has a residential grade Cub with a steering wheel and she won't touch an 'oar' mower and I can understand why now. Of course a Kubota F series diesel new will set you back around $23,000 bucks, way more than most people are willing to fork over for a lawn mower but you can find them used for a lot less and like everything Kubota, just because they are used don't mean they are shot. They will run long past the time that the rest will be junk, not including the JD units that are very similar in price and function.
/ What to Look for in Zero Turn Mower #14
Bottom line is, you can 'kill' any mower or tractor if you don't do regular maintenance on it and ZTR's are no exception.
The thing I like about the F series Kubota mowers is, they are essentially a B series Kubota compact tractor that has swapped ends, that is, front to back is now the opposite and we all know how B series Kubota tractors last. That aspect alone sold me on buying one and mine is used as well with 1500 hours on it.
/ What to Look for in Zero Turn Mower #15
What's the budget?
20 years ago I bought a commercial mower to handle my 2 acre yard. I went with a Kubota diesel ZD21 with a fabricated 60" deck. The lawn expanded over the years to about 5 acres. I have no regrets and am certain this mower will outlast me, (hopefully another 20 years....). It has almost 1000 hours now but runs like new. I've done nothing but fluid changes, blade changes and the front tire replacement.
/ What to Look for in Zero Turn Mower #16
We have a Ferris 2354GXLS that has done well on our three acres for about six years.
But I will say that folks next door have commercial acreage of about six acres that they only use for Halloween festivities.
They let it grow up all summer and then in the fall they have an outfit with two Exmarks come in and mow it all. At least five acres are hayfields that they "chop" down. Amazing to watch & the machines seem to hold up to the task.
/ What to Look for in Zero Turn Mower #17
On his mowers its crank seals and head gaskets mostly for both the Kaw and Kohler.
He trades before 2000 hrs.
Running an air cooled motor long and hard will result in more problems.
I have a Kohler Courage, supposedly the bad Kohler, thats pushing 1300 hrs with no problems. It also seems to have a lot more power than my new Kaw.
/ What to Look for in Zero Turn Mower #18
One feature I wish I on my zero turn is a flip up deck. I have never had one with the feature but they look pretty slick for easy deck cleaning and blade access.
/ What to Look for in Zero Turn Mower #19
For a flip up deck your choices are very limited, Kubota F series or a JD front mount or a Grasshopper front mount. No mid mount will have that feature.
/ What to Look for in Zero Turn Mower #20
I've found that the Kohler Courage that is on my wife's Cub has a weak starter. In fact I just bought a heavy duty starter to replace the wimpy one and it was almost 300 bucks. Wowzer. None of the pressure die cast aluminum blocked V twins will last as long as the older motors. I have a cast iron Kohler on my engine drive welder that is over 25 years old, runs like a top and starts right up and the sound a big Kohler makes when idling is pure music to your ears. It's a K241 btw. Only thing I had to do to it was replace the EPA non adjustable carb with one that was adjustable, a couple spark plugs and the normal oil and air filter changes. Back then Kohler built real engines. Not so today.
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2015 WESTERN STAR 4900EX (INOPERABLE) (A60736)
2015 WESTERN STAR...
2025 Pabreak 74in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 74in...
excavator trenching bucket- one bucket per lot (A61307)
excavator...
Kuhn FC400RG (A60462)
