Iseki TL2100 2WD explanation needed
   / Iseki TL2100 2WD explanation needed #1
Termes
Hungary
Iseki TL 2100
Hi, I need someone who tells me what the heck is in this pic. Thanks a lot! The translator is useless because of the missing parts. What is "L", "M", "H", "(M)" (low-high-middle?) Unfortunately the shifting sticker is in bad condition, cannot read a thing.
   / Iseki TL2100 2WD explanation needed #2
   / Iseki TL2100 2WD explanation needed #4
That is a chart with the travel speeds for your tractor given what gear and range it is. And looks like you got the 18 speed transmission by the looks of it.
1-2-3 are the main gears, L-M-H are your ranges.
L = Low range
M = Medium range
H = High range.
There could be another lever for the creeper gears, accordingly to the chart.
   / Iseki TL2100 2WD explanation needed #5
Edited the picture for you.
Let's say you want to go 2.3 km/h. You would put the main gear in "3", range gear in "Low" and creeper gear in "High".
   / Iseki TL2100 2WD explanation needed #7
I translated the last row text. The row with the (M) (M) (M) markings. This has me very curious what this does.
   / Iseki TL2100 2WD explanation needed #8
I did the same and noticed it as well. I didn't mentioned it to avoid confusion.
TractorData only lists two transmissions for that model but I wonder if there could be some other transmission option for it? Googling "Iseki Multi Shift" didn't bring much useful info.
   / Iseki TL2100 2WD explanation needed #9
Ah, you too Googled. Yep, we have not a clue. If it was a Yanmar, I would say, oh, that's just the PowerShift.
We would need someone with an Iseki-Mitsubishi setup to chime in on this one.
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2021 KOMATSU WA380-8 WHEEL LOADER (A60429)
2021 KOMATSU...
