Iseki TL2100 2WD explanation needed
   / Iseki TL2100 2WD explanation needed #1
Termes
Hungary
Iseki TL 2100
Hi, I need someone who tells me what the heck is in this pic. Thanks a lot! The translator is useless because of the missing parts. What is "L", "M", "H", "(M)" (low-high-middle?) Unfortunately the shifting sticker is in bad condition, cannot read a thing.
   / Iseki TL2100 2WD explanation needed #2
   / Iseki TL2100 2WD explanation needed #4
That is a chart with the travel speeds for your tractor given what gear and range it is. And looks like you got the 18 speed transmission by the looks of it.
1-2-3 are the main gears, L-M-H are your ranges.
L = Low range
M = Medium range
H = High range.
There could be another lever for the creeper gears, accordingly to the chart.
   / Iseki TL2100 2WD explanation needed #5
Edited the picture for you.
Let's say you want to go 2.3 km/h. You would put the main gear in "3", range gear in "Low" and creeper gear in "High".
   / Iseki TL2100 2WD explanation needed #7
I translated the last row text. The row with the (M) (M) (M) markings. This has me very curious what this does.
   / Iseki TL2100 2WD explanation needed #8
I did the same and noticed it as well. I didn't mentioned it to avoid confusion.
TractorData only lists two transmissions for that model but I wonder if there could be some other transmission option for it? Googling "Iseki Multi Shift" didn't bring much useful info.
   / Iseki TL2100 2WD explanation needed #9
Ah, you too Googled. Yep, we have not a clue. If it was a Yanmar, I would say, oh, that's just the PowerShift.
We would need someone with an Iseki-Mitsubishi setup to chime in on this one.
2005 International 4300 Telsta Telescopic Bucket Truck (A55973)
2005 International...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
More info coming soon! (A55787)
More info coming...
49205 (A55788)
49205 (A55788)
GENERATOR AND MOTOR (A55745)
GENERATOR AND...
