TODAYS SEAT TIME
   / TODAYS SEAT TIME #13,401
2 questions; (1) do you have a gravel driveway and (2)will those discs split?
Yes packed gravel ,I usually will run a water filled roller over it after more 3/4 minus is added.
I have never split it or changed the angle.
Not sure what you are asking on splitting the discs, if you mean having the bit of extra weight breaking a disc? , no, silty clay soil with almost no rocks.
   / TODAYS SEAT TIME #13,403
Take the rear set of discs off and use the front set to 'fluff' up the driveway. I do that with mine. Had to get a welder (I don't weld) to make me a three point hitch receiver for mine. It works good. These disks were the last of the drag discs made for Farmalls.
   / TODAYS SEAT TIME #13,404
That is a good idea but more work for me.
When I want to do that I have an old Servis brand rake with adjustable offset and wheels to set depth , plus I can angle and pull in the rock as well
pic is using it to clear pine needles.
   / TODAYS SEAT TIME #13,410
SR, it is always a good day when your tractor can make you money. :)
And instead of buying a plasticized, electrified new tractor for 20, 30 or even 40 thousand dollars, that more than likely will need repairs, before it's even paid for!
I choose to buy "forever" tractors made of steel, have no puter or def, and will easily last for thousands of hours, and will easily be paid for in one summer!
SR
   / TODAYS SEAT TIME #13,412
SR, there is no DEF or 'puter in my 2012 Kioti. I removed the grass burner exhaust 4 years ago and put up a 3" straight pipe that exits at the roof level. I get about 14 hours out of a tank of fuel working it hard. That is the way I worked it from day 1. I have about 6 years to go on the long life anti-freeze and this year it will get an oil change. It only gets an oil change every two years (10W30 synthetic) whether it needs it or not. Hydraulic oil got changed 2 years ago when I blew a line. That should be good for another 3 years.:)
   / TODAYS SEAT TIME #13,413
Is the hood steel or plastic? What controls the HST, solenoid controlled? How much does it cost to change the oil and filters in that hydro? Does it have an on/off switch for the pto? Does the key switch shut it off?
These are a few of the things that make a tractor very HARD to be a forever tractor.
   / TODAYS SEAT TIME #13,414
The hood is steel.
HST rocker pedal controlled.
Hydro change including filters (2) about $500.oo +/-
PTO manual controlled and never used.
Key switch does shut it off. Have an extra new solenoid for the shutdown.
Very seldom gets wet stacked. Almost always gets up to operating temps before I shut it down.
   / TODAYS SEAT TIME #13,415
Moved a mini-bulk container, 1/2 full with water to my farm. (no water source) Using it to mix herbicides & whatever else instead of making the 10 mile drive back home to refill. Then I gathered up 10 bucket loads of trees & trimmings I cut last week to recover some more of the property (old overgrown garden). Sprayed a few acres of clover plots for grasses/broadleafs/fert hopefully for a healthy growing season.
   / TODAYS SEAT TIME #13,416
The hood is steel.
Well, that's certainly better than some of the compacts, you are halfway to a forever tractor. lol
I paid $3500.00 for this one in the early/mid 1980's, it's a modern 30 hp tractor with 3 point that has position and draft control, full hydraulics, power steering, live power ect.., it also had a Howard Rotavator on the back.
As I said, I paid $3,500.00 for it and over the years I put 500 hours on it Rotavating for customers, and I cleared $35.00 for every one of those hours I worked it! Do the math on that, plus all the work it's done for me and is STILL working for me!
Total cost for parts I've bought for it since the "80's", about 10 bucks for a brass elbow on a hydraulic pipe that had a crack in it, and started to leak. Everything else has just been maintenance.
NOW, that's a forever tractor!
SR
   / TODAYS SEAT TIME #13,417
SR
I'll say! You got an awesome deal there!
My 2012 cost me with a front mount snow blower and cab and the loader $31,000.oo. Cab only has heat. If I would have gotten the CK 35 I could of had A/C as well. But at the time I was only using it for snow removal. Plunked 10 grand down and financed the rest over 5 years. All mine in 2017 and sat and thought about the grass burner until 2020, then changed the exhaust. It might be a little loud to some people but my winter customers have never complained. I only plow in daylight and the exhaust comes out of the manifold 1.75" and goes up into a 3" stack. The bigger stack dulls down the bark somewhat. I can dull it down more IF I was to go with a 4" stack.
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
