CK3510 Charging Issues
/ CK3510 Charging Issues #1
jbt308
Kioti CK3510SE
Afternoon everyone,
Recently discovered after doing some spraying that my tractor died. Checked the battery and it was dead, this is a new battery, less than 6 months old. Charged the battery and got it running and checked voltage across the battery, was only charging at 11.6v...checked the alternator lug B+? & ground, exactly the same 11.6v. So removed the alternator and took to a shop for a bench test, alternator checked out ok no issues.
So....what next? Alternator seems good, battery doesn't charge, etc... not sure what to look for next any help would be welcome!
/ CK3510 Charging Issues #2
Your system is not letting the alternator know it needs to charge. If your confident they did a load test on the alternator and your belt was tight, then you has a loose wire in the tractor. on my DK35, there is a plug of two wires that clip into the alternator. This is a voltage feed that sends the signal to the interior diode pack of the alternator and triggers the alternator to charge. Did you notice a battery or charge light on your dash? Without a wiring diagram, it can be tough to trace.
I would get that alternator retested, even if at an auto parts. Some will fail only when they get hot.
Been there, done that...got grey hair to prove it!!
/ CK3510 Charging Issues #3
One other thing...silly, but, check ALL your fuses. Kioti is Notorious for changing system without warning.
Just as a follow-up.
Checked the fuse, it was totally fine.
Alternator shop cleaned out the alternator, looked quite good.
Tightened the belt, tightened all bolts super snug, cleaned terminals
Charging @ 14.4v.....no idea, think it was just a culmination of circumstances. Going to install a voltmeter into the cab so I can keep an eye on things.
Appreciate everyone's responses, thank you!
/ CK3510 Charging Issues #6
It is probably your ignition switch. They are notorious for causing issues. Mine did the same thing. I sprayed some fluid film in it and worked it back and forth a bunch, and it's good for now. I'll have to pull my cab to replace it.
/ CK3510 Charging Issues #7
jbt308, I'm late to this thread, but my first suggestion would have been to check your belt tension. When you tightened your belt, were you able to notice any excess play?
I think I'd see how things work out for awhile before going to the trouble of adding a voltmeter to your cab! You may never have the problem again.
BTW, welcome to TBN!
2008 Detroit Diesel 200PJS6DT3 200kW Diesel Generator (A61572)
2008 Detroit...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
18.4-38 Clamp On Rear Duals w/Rims (A64119)
18.4-38 Clamp On...
2005 Ford F-350 Stakebody Flatbed Truck w/ Liftgate (A61573)
2005 Ford F-350...
1967 Hyster Equipment Trailer (A66285)
1967 Hyster...
24" Mini Excavator Bucket (A66285)
24" Mini Excavator...
