Venting a non-vented gas tank cap
/ Venting a non-vented gas tank cap #11
Would you lose the cap if you unscrewed it 1/4 or 1/2 turn when mowing, then screwed it back down when finished?
I just searched E-Bay for "VENTED JOHN DEERE GAS CAP", and a bunch popped up, most with what looks like a hole in the middle.
Yes the cap would vibrate off immediately.
This mower doesn't take the standard thread cap, presumably because it's pretty old as mowers go
/ Venting a non-vented gas tank cap #13
I like to fabricate things. A one way check valve like this $11.99 one, brass for fuel & would work. Hole in cap, thread on nut so air goes in but won't let fuel out.
/ Venting a non-vented gas tank cap #14
I'm not affiliated with the seller, but a quick search found me this on eBay. Looks like a small hole middle underside. Might this work for your application?
Yes looks like it will work, thanks. Part numbers match. I wasn't looking aftermarket and apparently I should have
/ Venting a non-vented gas tank cap #16
180 degrees from the first hole would create a single straight hole. 😁
I imagine you mean 90 degrees
I hope you're never lost in the woods. My compas has 360 degrees. If North is 0 then 180 is South. :cool:
/ Venting a non-vented gas tank cap #17
If you can't get a vented cap, make your own. Cut a round piece of plastic to fit tight to the underside on that seal area. Then put your holes in.
/ Venting a non-vented gas tank cap #18
Most vent holes in caps were smaller than 1/8"....more like 1/16"
/ Venting a non-vented gas tank cap #19
Probably I'd just drill a hole, J B Weld a 2" piece of steel tubing in it & stick a couple ft. of rubber vacuum hose on it.
1459 (A57192)
1459 (A57192)
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2024 Linx Trailer (A60462)
2024 Linx Trailer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
