Venting a non-vented gas tank cap
/ Venting a non-vented gas tank cap #1
MTGreen
Montana, USA
Deere 5220, Ford 1720, Deere Progator 2030
Have a Deere R70/R72 riding mower I recently refurbished. Has a gravity feed tank feeding a now 12hp single cylinder B&S.
Original gas cap was vented and in bad shape. I ordered a replacement part from Deere and got the part that superceded the original which fits but is not vented.
Didn't think much of it until I tried to troubleshoot why it would run great for 30 seconds to a minute then die. Runs great with the cap off but of course that's not a fix.
Thought about just drilling an 1/8" hole in the cap, or drilling a hole and epoxying in a hose nipple attached to some vacuum line.
Anyone have any better ideas?
/ Venting a non-vented gas tank cap #2
That should work but don't just drill it straight through. Drill one hole on an edge of the underside then drill the top hole 180 degrees from that. A straight through hole might gush gasoline.
/ Venting a non-vented gas tank cap #3
Could just buy the vented cap too. Part # AM100289
My 4x2 Gator has a non-vented cap and never stalls out. Not sure why ?? Must vent some other way than the cap.
/ Venting a non-vented gas tank cap #4
Is there another part that goes into the underside of that cap that makes it vent-able?
I had tried to order that part number and got the non vented substitute
I'm trying to understand how this works? The only way I can see that air can get into the tank is through a hole in the top round center of the cap -anything on the sides is blocked by the filler spout.
I can see this would work if the top was double walled with an air space in between, but unfortunately this cap has just a single layer of plastic
I'm afraid what you see in the pics are it
/ Venting a non-vented gas tank cap #8
A small hole may not seem like much but gas fumes will escape wasting gas and possibly creating a dangerous situation stored in an enclosed location.
I suspect as gas exits the tank a one way vale allows air in.
/ Venting a non-vented gas tank cap #9
A much smaller hole is required. I believe even a number 50 wire size drill hole will work just fine.
/ Venting a non-vented gas tank cap #10
180 degrees from the first hole would create a single straight hole. 😁
I imagine you mean 90 degrees
/ Venting a non-vented gas tank cap #11
Would you lose the cap if you unscrewed it 1/4 or 1/2 turn when mowing, then screwed it back down when finished?
I just searched E-Bay for "VENTED JOHN DEERE GAS CAP", and a bunch popped up, most with what looks like a hole in the middle.
Yes the cap would vibrate off immediately.
This mower doesn't take the standard thread cap, presumably because it's pretty old as mowers go
/ Venting a non-vented gas tank cap #13
I like to fabricate things. A one way check valve like this $11.99 one, brass for fuel & would work. Hole in cap, thread on nut so air goes in but won't let fuel out.
/ Venting a non-vented gas tank cap #14
I'm not affiliated with the seller, but a quick search found me this on eBay. Looks like a small hole middle underside. Might this work for your application?
Yes looks like it will work, thanks. Part numbers match. I wasn't looking aftermarket and apparently I should have
/ Venting a non-vented gas tank cap #16
I hope you're never lost in the woods. My compas has 360 degrees. If North is 0 then 180 is South. :cool:
/ Venting a non-vented gas tank cap #17
If you can't get a vented cap, make your own. Cut a round piece of plastic to fit tight to the underside on that seal area. Then put your holes in.
/ Venting a non-vented gas tank cap #18
Most vent holes in caps were smaller than 1/8"....more like 1/16"
/ Venting a non-vented gas tank cap #19
Probably I'd just drill a hole, J B Weld a 2" piece of steel tubing in it & stick a couple ft. of rubber vacuum hose on it.
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
King Kutter II Tiller for sale.
King Kutter II...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
Ford Pickup Truck Bed (A59230)
Ford Pickup Truck...
