Venting a non-vented gas tank cap
/ Venting a non-vented gas tank cap #1
MTGreen
Montana, USA
Deere 5220, Ford 1720, Deere Progator 2030
Have a Deere R70/R72 riding mower I recently refurbished. Has a gravity feed tank feeding a now 12hp single cylinder B&S.
Original gas cap was vented and in bad shape. I ordered a replacement part from Deere and got the part that superceded the original which fits but is not vented.
Didn't think much of it until I tried to troubleshoot why it would run great for 30 seconds to a minute then die. Runs great with the cap off but of course that's not a fix.
Thought about just drilling an 1/8" hole in the cap, or drilling a hole and epoxying in a hose nipple attached to some vacuum line.
Anyone have any better ideas?
/ Venting a non-vented gas tank cap #2
That should work but don't just drill it straight through. Drill one hole on an edge of the underside then drill the top hole 180 degrees from that. A straight through hole might gush gasoline.
/ Venting a non-vented gas tank cap #3
Could just buy the vented cap too. Part # AM100289
My 4x2 Gator has a non-vented cap and never stalls out. Not sure why ?? Must vent some other way than the cap.
/ Venting a non-vented gas tank cap #4
Is there another part that goes into the underside of that cap that makes it vent-able?
I had tried to order that part number and got the non vented substitute
I'm trying to understand how this works? The only way I can see that air can get into the tank is through a hole in the top round center of the cap -anything on the sides is blocked by the filler spout.
I can see this would work if the top was double walled with an air space in between, but unfortunately this cap has just a single layer of plastic
I'm afraid what you see in the pics are it
/ Venting a non-vented gas tank cap #8
A small hole may not seem like much but gas fumes will escape wasting gas and possibly creating a dangerous situation stored in an enclosed location.
I suspect as gas exits the tank a one way vale allows air in.
/ Venting a non-vented gas tank cap #9
A much smaller hole is required. I believe even a number 50 wire size drill hole will work just fine.
/ Venting a non-vented gas tank cap #10
180 degrees from the first hole would create a single straight hole. 😁
I imagine you mean 90 degrees
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A60736)
CAT FORKS W/ QUICK...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2000 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2000 Freightliner...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
