Venting a non-vented gas tank cap
   / Venting a non-vented gas tank cap #11
Would you lose the cap if you unscrewed it 1/4 or 1/2 turn when mowing, then screwed it back down when finished?
I just searched E-Bay for "VENTED JOHN DEERE GAS CAP", and a bunch popped up, most with what looks like a hole in the middle.
Yes the cap would vibrate off immediately.
This mower doesn't take the standard thread cap, presumably because it's pretty old as mowers go
   / Venting a non-vented gas tank cap #13
I like to fabricate things. A one way check valve like this $11.99 one, brass for fuel & would work. Hole in cap, thread on nut so air goes in but won't let fuel out.
   / Venting a non-vented gas tank cap #14
I'm not affiliated with the seller, but a quick search found me this on eBay. Looks like a small hole middle underside. Might this work for your application?
Yes looks like it will work, thanks. Part numbers match. I wasn't looking aftermarket and apparently I should have
   / Venting a non-vented gas tank cap #16
180 degrees from the first hole would create a single straight hole. 😁
I imagine you mean 90 degrees
I hope you're never lost in the woods. My compas has 360 degrees. If North is 0 then 180 is South. :cool:
   / Venting a non-vented gas tank cap #17
If you can't get a vented cap, make your own. Cut a round piece of plastic to fit tight to the underside on that seal area. Then put your holes in.
   / Venting a non-vented gas tank cap #18
Most vent holes in caps were smaller than 1/8"....more like 1/16"
   / Venting a non-vented gas tank cap #19
Probably I'd just drill a hole, J B Weld a 2" piece of steel tubing in it & stick a couple ft. of rubber vacuum hose on it.
2020 Chevrolet Express (A50120)
2020 Chevrolet...
Ziehl-Abegg Fan (A47384)
Ziehl-Abegg Fan...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2012 Audi Q7 AWD SUV (A50324)
2012 Audi Q7 AWD...
ATTENTION PLEASE READ (A50121)
ATTENTION PLEASE...
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
