Branson 2910i tractor dies while in use.
/ Branson 2910i tractor dies while in use. #1
sallyb
Colorado City, Texas
Mitsubishi Satoh Beaver 3 S373D, Branson 2910i
Tractor shows all fuses good, fuel shutoff solenoid getting 12.2 v, new fuel filter, air filter, will idle and drive about 100 ft then die, I am wondering if fuel pump or injectors are bad?
/ Branson 2910i tractor dies while in use. #2
If it starts OK after sitting, then takes off but runs slower and slower until it stops....that is the classic sign of fuel starvation. Could be anything from a plugged vent in the fuel cap to crud or a plastic bag in the fuel tank. I had one once where the old fuel line from tank to filter was collapsing.
If it starts and runs for awhile, it is unlikely to be the fuel pump or injectors. I'd suspect the cap, tank, solenoid, filter container or connections sucking air, and hoses collapsing or sucking air all before looking farther.
The old mechanic's trick to diagnose a fuel feed problem is to hang a small container of clean fuel above the fuel pump, connect it directly to the input of the fuel pump, and see if that cures the problem.
Thank you for answering,I started tractor today(Saturday) I timed it 2minutes then died suddenly, before it ran about 1 hr. then died suddenly. I turned key on and took fuel line off going to outlet side of fuel filter and diesel came out . Will try your tip of connecting fuel source to pump, thanks much, will keep you updated on progress.
/ Branson 2910i tractor dies while in use. #4
Sally, when you said it dies suddenly it almost sounds like a safety switch or relay problem. When it dies, can you cycle the key switch and it start again?
Yes after it sits, I have been looking for fuel tank for it, the plastic filler neck broke off several years ago, the tractor is 2007. I put in part number, but get no results, I am wondering about fuel sensor in tank could be clogged? Anyway I think dropping tank and replacing fuel lines . I think the repair manual shows fuseable link. Thank you,
/ Branson 2910i tractor dies while in use. #6
So you do not have a fuel cap anymore? Is there anything to keep trash from getting into the tank? If not, there definitely could be trash cutting of the fuel supply from the tank.
It will not be a bad fuseable link. When that blows the starter would not spin at all.
I put a rubber stopper in tank opening, it has been several years, I suspect that is probably big part of problem trash in fuel tank , is there a fuel pick pump in tank? I believe the tank needs replacing,
/ Branson 2910i tractor dies while in use. #8
No there is not a pickup pump in the tank. The fuel pulls out the bottom of the tank to the electric fuel pump. Sometimes there is a screen on the fitting in the tank but looking at the parts book for you model it doesn’t appear to have one.
Sometimes blowing air back through the line feeding the fuel pump will clear trash away from the fitting in the tank.
/ Branson 2910i tractor dies while in use. #9
If the plug she installed in place of the fuel cap is tight in the tank opening, there is no tank vent
/ Branson 2910i tractor dies while in use. #10
True but she said that happened a few years ago so something has changed.
It doesn’t vent from tank? So I replaced old rubber stopper with new one, so I tank would need replacing.
/ Branson 2910i tractor dies while in use. #12
Did the problem start after you put the new stopper in? Maybe try to run it with the stopper removed and see if it dies as a test.
I have used rubber stopper at lest 4years but it didn’t fit properly so maybe it wasn’t sealed, I started in August having problems, I changed fuel filter , and it would be ok then in September, while pulling up t-post that were on incline tractor suddenly died, I assumed it needed fuel, but that didn’t work, I talked brother told him what I thought was bad fuel shut off, we replaced shut off then there was no volts going to shut off, replaced all fuses and that seemed to solve problems, but then in January it started again. So it seems it all stems from fuel tank and rubber stopper.
Took stopper out and started tractor again it ran several minutes then died suddenly. I plan to get under tractor and replace fuel lines and check connections for clogging. After that if that doesn’t work, I guess have injectors checked. Is there a possibility of using another fuel tank maybe modify the way it’s supported say using metal straps? I drilled a small hole through stopper, I can see daylight through it.
/ Branson 2910i tractor dies while in use. #15
I do not believe it will be injectors at all. Something is blocking fuel or a safety switch is turning the tractor off.
I hope injectors are ok. I will look in manuals find where safety switch is located. Thank you your help is appreciated.
/ Branson 2910i tractor dies while in use. #17
Dead bug in the fuel pump would cause that. Ask me how I know.
Maybe that’s what has happened, the engineer died.lol, sorry but I need to laugh helps me not to cuss problem, that I probably created.
/ Branson 2910i tractor dies while in use. #19
The fuel may have softened the rubber to the point that it now makes a complete seal of any air venting into the tank.
Similar problem on my old Jinma 284... the fuel screen on the inside of the tank had gotten so bad over 20yrs that it wasn't allowing enough fuel to flow quickly enough into the fuel filter. So it ran with the amount of fuel in the larger fuel filter I had added to the tractor, but then couldn't keep up with the flow. Replaced that screen with some stainless steel mesh, and has been working fine.
/ Branson 2910i tractor dies while in use. #20
Try running the tractor with the tank "cap" removed, if that solves the problem drill a small hole in the plug to vent the tank.
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A59911)
2018 INTERNATIONAL...
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2014 Ford Focus Sedan (A61574)
2014 Ford Focus...
