Odd situation : only half of chain teeth beat up
/ Odd situation : only half of chain teeth beat up #1
frogpond
Snohomish WA
Kubota BX25D
I went to sharpen the chain on my Stihl ms261cm after it got dull( probably hit some dirt while bucking up a maple). Only the teeth pointing one way had ragged cutting edges, while the ones pointing the other way were just a little dull, but undamaged. What could hsve caused this?
It's a Stihl semi chisel 3/8 chain on a 20" lightweight bar.
/ Odd situation : only half of chain teeth beat up #2
It’s pretty common for chainsaw chains to just get damaged on one half. A gravel stuck in the bark could have easily done it.
/ Odd situation : only half of chain teeth beat up #3
I have had this happen and found something stuck under the removable sprocket drive cover.
/ Odd situation : only half of chain teeth beat up #4
Happens to me all the time, hit a rock, nail, piece of fence wire with the bar tilted to one side and it only dulls the teeth on that side.
/ Odd situation : only half of chain teeth beat up #5
Years ago I found square nails deep inside an old oak.
/ Odd situation : only half of chain teeth beat up #6
The worst of it is that now you will have to sharpen those teeth more than the other side and will wind up eventually tossing a chain with only half the teeth worn out.
On the brighter side, the difference in size of teeth doesn't really affect the cutting or tracking of the chain...
/ Odd situation : only half of chain teeth beat up #7
happens all the time, the debris was on that side or its simply that side that caught it. Is you rakers files down the same ? that's could impact this if it's not the case but then your saw would cut crooked as well.
Oh well, so much for my theory about one-armed gremlins...
I file all the rakers the same. I use a Stihl 2in1 for filing, and also round the leading edge of the rakers after a while. After this occurrence, I filed all the teeth to the same size, of course.
/ Odd situation : only half of chain teeth beat up #9
I don't do that... I file it until its sharp and stop, yes I end up with some teeth longer then others but next time it could be the long one that get hit...
/ Odd situation : only half of chain teeth beat up #10
I also use the stihl 2in1 and find it excellent.
I disagree that it is necessary to sharpen the teeth evenly, I think you are wasting material, time and chain life by doing so.
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
Blue Diamond 103709 (A53317)
Blue Diamond...
Ford 8210 (A60462)
Ford 8210 (A60462)
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
2017 Ford F-250 Pickup Truck, VIN # 1FT7W2B63HED67208 (A61165)
2017 Ford F-250...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
