Odd situation : only half of chain teeth beat up
   / Odd situation : only half of chain teeth beat up #1
frogpond
Snohomish WA
Kubota BX25D
I went to sharpen the chain on my Stihl ms261cm after it got dull( probably hit some dirt while bucking up a maple). Only the teeth pointing one way had ragged cutting edges, while the ones pointing the other way were just a little dull, but undamaged. What could hsve caused this?
It's a Stihl semi chisel 3/8 chain on a 20" lightweight bar.
   / Odd situation : only half of chain teeth beat up #2
It’s pretty common for chainsaw chains to just get damaged on one half. A gravel stuck in the bark could have easily done it.
   / Odd situation : only half of chain teeth beat up #3
I have had this happen and found something stuck under the removable sprocket drive cover.
   / Odd situation : only half of chain teeth beat up #4
Happens to me all the time, hit a rock, nail, piece of fence wire with the bar tilted to one side and it only dulls the teeth on that side.
   / Odd situation : only half of chain teeth beat up #5
Years ago I found square nails deep inside an old oak.
   / Odd situation : only half of chain teeth beat up #6
The worst of it is that now you will have to sharpen those teeth more than the other side and will wind up eventually tossing a chain with only half the teeth worn out.
On the brighter side, the difference in size of teeth doesn't really affect the cutting or tracking of the chain...
   / Odd situation : only half of chain teeth beat up #7
happens all the time, the debris was on that side or its simply that side that caught it. Is you rakers files down the same ? that's could impact this if it's not the case but then your saw would cut crooked as well.
Oh well, so much for my theory about one-armed gremlins...
I file all the rakers the same. I use a Stihl 2in1 for filing, and also round the leading edge of the rakers after a while. After this occurrence, I filed all the teeth to the same size, of course.
   / Odd situation : only half of chain teeth beat up #9
I don't do that... I file it until its sharp and stop, yes I end up with some teeth longer then others but next time it could be the long one that get hit...
   / Odd situation : only half of chain teeth beat up #10
I also use the stihl 2in1 and find it excellent.
I disagree that it is necessary to sharpen the teeth evenly, I think you are wasting material, time and chain life by doing so.
   / Odd situation : only half of chain teeth beat up #11
I also only sharpen until it is sharp...not until it is even with the other teeth.
   / Odd situation : only half of chain teeth beat up #12
I used to do the same thing until I read Stihl’s sharpening guide material. After reading the guide I went out and took 7 old chains and sharpened the chain including taking down the depth gauge accordingly. The difference between sharp and awesome came through loud and clear. If you want to see chips fly like butter - do it by the book
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2383 (A60432)
2383 (A60432)
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
2017 PETERBILT PB337 HYDRA-TAIL FLATBED TRUCK (A59823)
2017 PETERBILT...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
