Odd situation : only half of chain teeth beat up
   / Odd situation : only half of chain teeth beat up #1
frogpond
Snohomish WA
Kubota BX25D
I went to sharpen the chain on my Stihl ms261cm after it got dull( probably hit some dirt while bucking up a maple). Only the teeth pointing one way had ragged cutting edges, while the ones pointing the other way were just a little dull, but undamaged. What could hsve caused this?
It's a Stihl semi chisel 3/8 chain on a 20" lightweight bar.
   / Odd situation : only half of chain teeth beat up #2
It’s pretty common for chainsaw chains to just get damaged on one half. A gravel stuck in the bark could have easily done it.
   / Odd situation : only half of chain teeth beat up #3
I have had this happen and found something stuck under the removable sprocket drive cover.
   / Odd situation : only half of chain teeth beat up #4
Happens to me all the time, hit a rock, nail, piece of fence wire with the bar tilted to one side and it only dulls the teeth on that side.
   / Odd situation : only half of chain teeth beat up #5
Years ago I found square nails deep inside an old oak.
   / Odd situation : only half of chain teeth beat up #6
The worst of it is that now you will have to sharpen those teeth more than the other side and will wind up eventually tossing a chain with only half the teeth worn out.
On the brighter side, the difference in size of teeth doesn't really affect the cutting or tracking of the chain...
   / Odd situation : only half of chain teeth beat up #7
happens all the time, the debris was on that side or its simply that side that caught it. Is you rakers files down the same ? that's could impact this if it's not the case but then your saw would cut crooked as well.
Oh well, so much for my theory about one-armed gremlins...
I file all the rakers the same. I use a Stihl 2in1 for filing, and also round the leading edge of the rakers after a while. After this occurrence, I filed all the teeth to the same size, of course.
   / Odd situation : only half of chain teeth beat up #9
I don't do that... I file it until its sharp and stop, yes I end up with some teeth longer then others but next time it could be the long one that get hit...
   / Odd situation : only half of chain teeth beat up #10
I also use the stihl 2in1 and find it excellent.
I disagree that it is necessary to sharpen the teeth evenly, I think you are wasting material, time and chain life by doing so.
1273 (A50490)
1273 (A50490)
2018 INTERNATIONAL LT625 SLEEPER TRUCK (INOPERABLE) (A52472)
2018 INTERNATIONAL...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
1997 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1997 HEIL TRAILER...
