Concrete Slab thickness for Bin Blocks
/ Concrete Slab thickness for Bin Blocks #1
bridge4
Western,MA
Mahindra 2638, Bobcat MT 100
Hey All,
I am going to be opening up an area for some material and equipment storage and I had a question. In part of the area I am thinking of pouring a slab, so that when I scoop up the mulch/topsoil/stone/etc.. its nice and clean and I don't get any dirt in it. I know that one option is just be a better operator, well I am working on that...
In the meantime, I was thinking of putting a 5" slab down, and stacking bin blocks (2-2.5) high around the edges to contain and separate the material. My ? is, can I stack the blocks on a slab that deep? Or should I be stacking the bin blocks, then pouring inside their footprint?
Going to work with a neighbor to do this and trying to get a good plan together before we go too far.
Thanks in advance.
/ Concrete Slab thickness for Bin Blocks #2
A big part of depth needed is the material under the concrete. If it's clean and well compacted, you won't need as much. If it's loose material that is going to shift underneath, or there are rocks that the frost is going to move around, the thicker, the safer.
Where I am, once you go down a foot or two its all gravel. My thought is to scrap the topsoil off, put down some crushed stone, compact, and pour on top of that. I don't think there are many huge boulders/rocks in the area, but there certainly are some.
/ Concrete Slab thickness for Bin Blocks #4
I'd definitaly plan on stacking the blocks on the concrete. They will stack nicer and wont settle or lean.
While those blocks are big and heavy, they have a large footprint.
2x2x6 blocks that weigh almost 2-ton but have 12 sq ft of footprint.
4" of concrete is more than enough, especially if you strip 4-6" of topsoil and put in 4-6" of crushed stone and compact it.
/ Concrete Slab thickness for Bin Blocks #5
Why such big blocks? I'm thinking of doing something similar for my manure from the animals, and I was going to use cinder blocks with rebar, and then fill with concrete. Mine will be build into the side of a slope, so the blocks will also act as a retaining wall. I'm planning on 4 inches of concrete on top of virgin soil. I'm not putting any rock under it, but I'm in East Texas, and nobody puts rock under concrete here.
/ Concrete Slab thickness for Bin Blocks #6
I'm curious as to why you plan to use bin blocks since you're pouring a slab. Why not use CMU blocks or pour the separator wails? They can be tied into the slab with rebar and don't take as much space as the bin blocks.
Thanks! I appreciate that information, very helpful.
I am up north, an frost and soil movement in the seasonal changes require it I believe if I want it to last.
I am going to use bin blocks so that I can smash into it a bit and never worry. I also think the simpler process should save some time and money, maybe I am wrong though. The crane sets them, and I forget them. I am not super concerned about the space, what I have planned includes extra room for the blocks. The other reason, is that this set up may not stay here forever. This way I have the ability to move the wall and use them in another area. My plans always change and having the ability to move them around at some point to use them in another area is appealing to me.
/ Concrete Slab thickness for Bin Blocks #8
I looked into bin blocks for this and similar uses and decided that because I don't own something that has enough lift, the costs of purchasing them and having a crane set them ended up being substantially more than rebar and poured concrete. If you can move them yourself, that's a totally different story.
So, I would suggest a poured wall, or as @EddieWalker suggested rebar and filled cinder blocks. If you do decide to move it, a couple of hours with a concrete saw would have it reduced enough to remove.
All the best,
Peter
/ Concrete Slab thickness for Bin Blocks #9
Back in the 60's my neighbor built what you want to build. He pored concrete and rebar and let it cure for a week or so before using it. His ford tractor with loader pushed the back wall out the following summer.
I would make the back-wall and floor joint homogenous and very thick with lots of heavy rebar.
/ Concrete Slab thickness for Bin Blocks #10
I'd be tempted to dig down a bit lay down highway fabric and a bit of gravel, then set the mafia blocks and pour inside of them.
/ Concrete Slab thickness for Bin Blocks #11
You don't have frost to contend with. We need a better base and drainage to keep the ground from moving when it freezes.
/ Concrete Slab thickness for Bin Blocks #12
I just stacked my blocks on the ground. I hauled them myself when I had my Mack . I paid $20. each.
I believe that the last time I bought some they were $55.
I am seeing pricing around that to 60, I need to talk more with a few places and see if any have a crane truck, that way they can place them for me.
I don't have the ability to lift them myself, but I have two neighbors who can, and would be willing. Having the truck just do it while its dropping them off seems easiest though if the extra cost isn't too much.
View attachment 858552I just stacked my blocks on the ground. I hauled them myself when I had my Mack . I paid $20. each. View attachment 858551
Like the backfilling, I think I am going to try to get my first layer at least covered. Any movement or anything when scrapping up the pile? Looks solid to me.
/ Concrete Slab thickness for Bin Blocks #16
Local town has setup for their different gravels. They poured slab and stack blocks on slab. They use loader with one yard bucket to move material. Still looks good after five plus years
Bulk Bin (A66408)
Bulk Bin (A66408)
2017 Toro GrandStand 52in Stand-On Mower (A64553)
2017 Toro...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump (A64194)
2025 LandHonor...
New/Unused 20x30 All Steel Carport (A65583)
New/Unused 20x30...
2015 International 4300 Elgin Broom Bear Sweeper Truck (A64556)
2015 International...
