Car Lift for Regular Sized Garage
/ Car Lift for Regular Sized Garage #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Since I can’t stop fixing things…
I hope to one day build a detached garage/shop but for now I have my two bay garage. It’s 22 x 22; obviously a portable setup is needed and I’m wondering about one that will go up 24” or so… I’m guessing a mid height one might not fit on one side - what do the experts say and use?
/ Car Lift for Regular Sized Garage #2
HF sells a low ceiling lift. Been contemplating one actually. Think the sell it anyway, used to.
/ Car Lift for Regular Sized Garage #3
For a short portable two post lift, look up MaxJax.
I think you can even get a lounge chair on wheels to cruise around under the car with.
The alternative would be a scissor lift.
/ Car Lift for Regular Sized Garage #4
I use this Bendpak 4 post lift in my 24 x 40 garage:
It has an optional wheel kit which makes it easy to move around the building. When not being used to work on vehicles, it makes a great storage platform. You can also park a vehicle underneath, which means it takes up little floor space.
You might want to check out this thread on the subject:
/ Car Lift for Regular Sized Garage #5
Do to limited ceiling height I use Quick Jacks.
Works well on the cars, but not high enough to lift my truck tires off the ground.
This looks fantastic. First step is to see if my concrete floor is thick enough.
/ Car Lift for Regular Sized Garage #7
I looked at the Maxjax a few years ago. I decided it just wasn’t worth it. I have about a 8’6” ceiling height and figured my electric door opener would have to be switched out to get it out of the way. I’ve been sticking with a nice floor jack and axle stands and for a lot of things like oil changes I use a pair of ramps called Race Ramps.
/ Car Lift for Regular Sized Garage #8
There are a number of wall mount or jack shaft garage door openers that open up ceiling space.
/ Car Lift for Regular Sized Garage #9
Holy crap! I never knew you could move 4 post lifts around! Post of the year for me!
/ Car Lift for Regular Sized Garage #10
I have a friend that has a max jax lift in his 2 car garage. Said it made life easier for him as a retired mechanic to do side work and let him keep working like he enjoys.
/ Car Lift for Regular Sized Garage #11
I've thought about burying one of these in the garage.
Perhaps a sign that one has jumped the shark. However, when it is down, it would be largely out of the way.
/ Car Lift for Regular Sized Garage #12
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2007 Honda CR-V SUV (A59231)
2007 Honda CR-V...
9ft. Flatbed Truck Body with Gooseneck Connection (A59230)
9ft. Flatbed Truck...
2021 Ford F-250 4x4 Crew Cab Pickup Truck (A59230)
2021 Ford F-250...
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
