Attaching Winch to Front of Tractor?
   / Attaching Winch to Front of Tractor? #51
I think it'd be most helpful to know what the winch would be used for, and how often.
About two years ago I installed an 18K winch on one of the Unimogs, one of maybe two dozen winches I've added to various vehicles, basically to be able to upright a tractor if needed.
That was the most complicated mount to make to date, due to very little space to work with, but being able to pull the skid steer out a couple of times made it well worth it.
Was that for a UniMog PTO winch?
   / Attaching Winch to Front of Tractor? #52
I'd love to see pics of it installed and your hydraulics connection to it.
I will plan on getting some pictures and posting them. I will probably be Wednesday before I have time. Long story, but my tractor shed is only 12' wide and I have to climb over stuff to get at the front of the tractor, and then I don't have lights in there. I will have to back the tractor out to take the pictures. I think the dealer did an excellent job on it, so I don't mind showing them.
   / Attaching Winch to Front of Tractor? #53
No, there's no PTO capability on that particular model. It's used up by a pump for the rear hydraulics, which power the backhoe.
So I went with an electric 18K ComeUp. One big advantage is that it can be operated remotely, so I can be in stuck vehicle while winching.
   / Attaching Winch to Front of Tractor? #54
I do think a capstan winch, either PTO, hydraulic, or Honda engine driven will be the way to go for me. Another thing to remember about electric winches is that if you are doing a recover at night (4wd, etc), you will also have the electrical load of your off-road lights.
   / Attaching Winch to Front of Tractor? #55
Here are some pictures I have of the tractor and installation. Hope this helps. The picture with the hoses is where they mounted the hoses with the quick connects so I could easily disconnect the winch and connect the hoses for the grapple.
   / Attaching Winch to Front of Tractor? #57
Is the winch hooked up to a third-function valve?
   / Attaching Winch to Front of Tractor? #59
I added a second remote just for the winch/grapple on the front. I leave the original remote for the bachhoe.
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
2852 (A58376)
2852 (A58376)
1999 EZ-GO Golf Cart (A56859)
1999 EZ-GO Golf...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
