CliffordK
- Joined
- Mar 8, 2013
- Messages
- 2,426
- Location
- Eugene, Oregon
- Tractor
- Toro D200, Ford 1715, International 884,
Sure it will depend on the use and length of pull.I really have doubts on that statement because it depend on size of winch, size of power to operate winch, how stuck you are or vehicle you are rescuing....
I have a Jeep that weighs in at 4500 pounds, with 10,000 (+/-) lb. pull winch in front and have to block all four wheels, and it took two attempts to get 1400 pound (more like 2,200lbs, with FEL and ballast) stuck tractor out of bog.... And Yes Jeep has 950 CC battery and 100 amp alternator and during both pulls I pulled Jeep system battery down to 9 volts (with engine running) and had to back off to recover, because at 8.5 (+/-) Jeep system voltage computer craps out.....
I do almost all of my pulling with an independent battery and a Harbor Freight 12K winch. The BADLAND ZXR 12K locked up on me, and I'm now using the BADLAND Apex 12K. I probably don't ever hit the 12K, and probably don't want to with the Harbor Freight winches.
The battery I typically use is the Odyssey PC1700T.
I loaded a non-running Oliver AG-6 crawler onto my trailer with the ZXR. Somewhere around 7,000 lbs.
The ZXR died loading my Grumman step van. Killed the winch, not the battery.
I got my Ford 1715 stuck. Right front and rear wheels a foot or so over a bank. Enough that it wouldn't safely self-recover. So, the Apex winch connected to a tree and pulled the Ford back up onto solid ground. Not too long of a pull, but pretty awkward pulling up and to the side.
I pulled the F150 about 50 yards through mud. Not stuck, but I was having troubles with it side-slipping, so it was easier to rig it so it wouldn't side-slip, and then slowly winched it along.
I think it was my Bobcat 610 that I pulled about 100 yards uphill. I think with that one I did trickle charge the battery some. But, mostly just pulled.
Unloading a vehicle is often easier, but it may involve moving it around a bit. So, I'm not doing any cliffside recoveries, and try not to let my vehicle sink in to the axles.
I like to recharge after loading/unloading, but at times the battery remains close enough to full that it doesn't take much charging.
I generally don't like wiring into a starter battery and winching while the vehicle is off.
However, I think I did that some with my old Blazer and Warn 8K.
