Attaching Winch to Front of Tractor?
   / Attaching Winch to Front of Tractor? #51
I think it'd be most helpful to know what the winch would be used for, and how often.
About two years ago I installed an 18K winch on one of the Unimogs, one of maybe two dozen winches I've added to various vehicles, basically to be able to upright a tractor if needed.
That was the most complicated mount to make to date, due to very little space to work with, but being able to pull the skid steer out a couple of times made it well worth it.
Was that for a UniMog PTO winch?
   / Attaching Winch to Front of Tractor? #52
I'd love to see pics of it installed and your hydraulics connection to it.
I will plan on getting some pictures and posting them. I will probably be Wednesday before I have time. Long story, but my tractor shed is only 12' wide and I have to climb over stuff to get at the front of the tractor, and then I don't have lights in there. I will have to back the tractor out to take the pictures. I think the dealer did an excellent job on it, so I don't mind showing them.
   / Attaching Winch to Front of Tractor? #53
No, there's no PTO capability on that particular model. It's used up by a pump for the rear hydraulics, which power the backhoe.
So I went with an electric 18K ComeUp. One big advantage is that it can be operated remotely, so I can be in stuck vehicle while winching.
   / Attaching Winch to Front of Tractor? #54
I do think a capstan winch, either PTO, hydraulic, or Honda engine driven will be the way to go for me. Another thing to remember about electric winches is that if you are doing a recover at night (4wd, etc), you will also have the electrical load of your off-road lights.
   / Attaching Winch to Front of Tractor? #55
Here are some pictures I have of the tractor and installation. Hope this helps. The picture with the hoses is where they mounted the hoses with the quick connects so I could easily disconnect the winch and connect the hoses for the grapple.
   / Attaching Winch to Front of Tractor? #57
Is the winch hooked up to a third-function valve?
   / Attaching Winch to Front of Tractor? #59
I added a second remote just for the winch/grapple on the front. I leave the original remote for the bachhoe.
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2012 BMW 328i Coupe (A56859)
2012 BMW 328i...
CAT Chassis Only (A59076)
CAT Chassis Only...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
