How hard is it to learn to use a rental mini-excavator?
/ How hard is it to learn to use a rental mini-excavator? #41
Only 1 way to learn how to operate any equipment. Get in an open area and play with it. You can read instructions, talk to old hands, get advice, but until your butt has sweated in the seat you won't know s--t! The main thing to have with you all the time is common sense. Don't get on the machine without it.
/ How hard is it to learn to use a rental mini-excavator? #42
I've been a member of this forum for a long time and appreciate the advice offered hear. I'm the proud owner of two Steiner 240's. I have two properties and they serve me very well for mowing, dirt moving and snow blowing. Last summer the machine in the picture moved 1000 yards of fill and gravel and it was maybe the best summer of my life!!! I personally think that the flexibility, power and durability make Steiner/Ventracs a very good long-term value for a mechanically inclined homeowner like me.
My place in Maine has tree stumps that are out of range for a 22 HP machine. I can push 24" and smaller stumps around once they are loose, but I can't get them dislodged.
I'm considering renting a mini-excavator to dig about 10 stumps in the 12 to 24" range. My question is, how steep is the learning curve for a mini-excavator for someone who has lots of hydraulic tractor experience? Can I reasonably expect to dig 10 stumps in a day starting with no mini-excavator experience?
it's easy and quick to learn. the track Hoe is about the same as operating a back hoe but I believe is a faster and better machine then the back Hoe
/ How hard is it to learn to use a rental mini-excavator? #43
You have multiple questions. First how long does it take to learn to operate the excavator. Answer: That depends on you and your adaption of hydraulic controls, hand-eye coordination. Second is the amount of time to remove the stumps. That’s loaded with variables and how well you have learned to operate and now you must focus on the stump and its roots. Sometimes on larger roots you need to use the teeth or tooth to split and tear the root away in pieces or have a big enough machine to do in one pass. You get the most power from pointing the tip of the tooth and cutting edge in the direction of travel.
But before you get to those stages you must consider the whole purpose of what you are doing. If you just want to clean up the land or are you planning on building something there or planting where the stumps were. In the world of professional building when you have a soils engineer who sets standards for your building you need to remove the stump several feet down and the roots to satisfy the specifications. A stump grinder will just make it harder and accomplish nothing. Like some said you need to remove the stump with the roots attached.
If you plan on planting, a stump grinder might work but often new growth doesn’t work well in those areas. Once you consider what you want to accomplish then go from there. You may find a bigger excavator is cheaper because it works faster against the task you have.
/ How hard is it to learn to use a rental mini-excavator? #44
I suspect that some of the most knowledgeable folks might be found at the rental vendor. After all, they've been delivering their machines to amateur and old hands and likely have a few horror stories if they've been in business a while. As well, they might prove helpful in relating the experiences of other customers.
Here, if you rent it for Saturday, you don't have to return it 'till Monday for the 1-day fee.
They might also be willing to put you in the seat, fire it up and let you get the feel of the thing before you commit.
Remember, if you don't ask, they can't say "Sure, we can do that."
/ How hard is it to learn to use a rental mini-excavator? #45
I rented a kx033 for some ditching and Landscape work around the house. I have a 5-year-old who loves all things machine related and all things dinosaur. After I had finished using it I parked the machine up in the woods idled it put the back fill blade down and showed him how the controls worked one time. I then stood back and watched him for about 10 minutes while he proceeded to dig a hole approximately 10 ft deep trying to get down to "dino level" to find dinosaur bones. They're pretty intuitive and you won't have any problem.
They say farming is one of the most dangerous places for children. And the picture of this child (unable to sit as intended) without so much as a seat belt much less a safety helmet speaks volumes on the topic.
https://marshfieldresearch.org › Media › Default › NFMC › PDFs › ChildAgInjuryFactsheet2020.pdf
Childhood Agricultural Injuries (U.S.) 2020 Fact Sheet 60%
All Youth. Every day about 33 children are injured in agriculture-related incidents.**. In 2014, an estimated 7,469 household† youth were injured on a farm and 60% of them were not working when the injury occurred.7. An estimated 738 hired youth were injured on farms in 2014.7. Approximately 3,735
  • Good Post
Reactions: D&D
/ How hard is it to learn to use a rental mini-excavator? #46
I have done both, highly recommend grinding the stumps. Saves a lot of work. Unless you’re a professional with a 12,000 pound machine it will take you three days to dig them out.
/ How hard is it to learn to use a rental mini-excavator? #47
Pretty easy to operate. I rented one for a weekend expecting it to take much longer than it did. Dug out 112' length x 4' deep trenches for a barn foundation in a few hours (all sand), then yanked out some small trees, and returned it for only a 4 hour rental.
One what? From what I've seen at the rental place here, there are at least three different sizes and, from what I've seen at various job sites, there are more and larger units, too.
It would help if we all tried to add important details 'cause one of the little excavators I can tow home with my Tacoma base isn't going to dig out a four foot trench around a 112' perimeter in four hours - it takes 30 minutes to drive the thing from the Home Depot and as many minutes for the return trip, parking, unloading, loading lots of little minute eaters.
/ How hard is it to learn to use a rental mini-excavator? #48
I've also rented on weekends. Most machines have hour meters. Over eight hours (with a little leeway) is charged either proportionally or in full days around here, depending on outfit.
/ How hard is it to learn to use a rental mini-excavator? #49
Best way to get stumps out in my experience using my Ford 555D backhoe is to not cut the tree down at all. Dig a hole on the side of the trunk away from where you want the tree to fall, break or cut the roots on that side, then reach up high and push it over with the bucket. Leverage and weight at the top of the tree helps a *lot* here. 99% of the time I've tried this, the whole root ball pops right out.
And I would not put a 5 year old kid in a machine of this type of capability without being in there with him. Not a good idea. Only takes one wrong move for him or someone else to get hurt, or massive property damage to occur. Kids freeze up when something goes wrong. Can drive right over someone or a car or a house that way, or roll down a hill, etc. If, as the owner of that machine, I saw that someone I rented it to did that, they'd never rent one of my machines again.
/ How hard is it to learn to use a rental mini-excavator? #50
All boils down to coordination and wiring your brain to the actions of your hands.
After a few hours, you start to get the hang of it. After a few days it will start to become second nature.
Turn the machine back in and rent again in a couple years and you will have re wire your brain/hands again. :D
/ How hard is it to learn to use a rental mini-excavator? #51
I haven’t run one but I had a man do some work for me who had run one many times. He was working on a slight slope and nearly tipped over. So all I say is be careful and stay within your boundary of caution.
/ How hard is it to learn to use a rental mini-excavator? #52
I'm not so sure I would want to use a mini for this job. I used a 10T (maybe a bit overkill, but it was available from neighbor JD 75G) to remove about a dozen trees (Oak, Pine, Pear, Cedar, etc), dug a new septic & drain field and dig dirt to level a new 50 x 100 slab. Trees took about 4 hours. Septic about 1.5 hrs Dirt about 10 hours because of limestone shelf I encountered. Used a med dozer to level. BTW, it's much easier to pull the stumps if the trees are still attached!
That track hoe made pulling the hard & soft wood trees really easy. I think a mini would take all day just trying to dug out the roots if your trees have nearly the root ball mine had.
Overkill? I thought 27 tons was too small
/ How hard is it to learn to use a rental mini-excavator? #53
I own a Bobcat E42 cab mini-ex, it weighs about 10,000 pounds ready to work. Bought it new in 2019 for our ranch and never previously operated an excavator. I have over 800 hours operating a small Kubota (30 hp) and my Deere 4720 (66 hp) so lots of tractor seat time.
As far as the learning curve I think that depends on the person, some might be semi-productive after four hours in the seat but it took me 20 hours of seat time. When I say "productive" that means you have acquired muscle memory to where you don't have to think and review in your mind every operation of the boom/stick/swing/curl, etc, etc. Now I instinctively move the joysticks to do the work.
Even though I have 150 hours on my E42, if I haven't operated it in a few weeks it always takes me several minutes to get comfortable with the joysticks.
So about the stumps. How long to dig out depends on the tree and root system. Even the smaller diameter stumps can take 45 minutes plus to dig out. I spent probably an hour digging our a dead shin oak stump, I thought I was going to pop it out in a few minutes but no sir. I had to dig up the entire root system. Bear in mind my E42 is a pretty powerful mini-ex for its size, I can dead lift over two tons and breakout force is significant.
If the stump has been dead for a few years, it might pop right out (or not LOL.) I was digging out several oak stumps three years ago to make room for our new garage and one of the stumps was a double trunk oak that we cut off about three feet above ground. I spent about six hours digging and pulling, my contractor buddy spent half a day doing the same. We finally had a stump grinder service come out and grind the roots, fortunately his machine telescoped out so he could reach all around the stump.
When we finally popped out the stump, it was massive like an iceberg. I had to pull the stump in with the bucket and pull it up on the blade and rest it there. It was too heavy to lift and move just by picking it up.
My E42 (the "hoe") doesn't get used a whole lot but when I need it, it pays for itself. One job for it occasionally is burying dead animals (we raise blackbuck antelope), I can dig a hole deep enough to keep other critters from digging up the carcass in about ten minutes. It usually takes longer to get to the burial site than it does to dig the hole. Then I use the hoe to grab the carcass and drop it in the hole.
Hope this helps someone thinking about renting a mini-ex.
/ How hard is it to learn to use a rental mini-excavator? #54
As for learning to run a mini-excavator, I would not be surprised if you learned quickly. As long as you are out in the open and not trying to do something like digging a French drain up next to a house, just go for it. It's a ton of fun running an excavator. It can be very satisfying work.
As stated by many already, the type of soil, the type of tree, the health of the tree, etc. are all significant variables. Some trees have massive tap roots, others don't. I have a Yanmar Vio55 (12k lbs) and also a Cat 312E (33k lbs). Just a couple of days ago, I dug out 12 smallish oaks, 6" to 12" in diameter in less than an hour with the 312E. The trees were full height. I made a good scoop on one side (more if needed) and then pushed towards the hole, then grabbed the tree with the thumb, and out they came. The soil was loamy and moist - optimal conditions. When the Cat was busy, I used the Yanmar for a couple of trees, which took 15-20 minutes per tree on average.
I think something like the E42 mentioned above or even a 50-55 class (like my Vio55) would serve you well and they don't need a lowboy to haul.
/ How hard is it to learn to use a rental mini-excavator? #55
For stumps, I would get a 20-40 ton machine rental as long as you dont have really tight quarters. Getting started with using it is pretty easy. Getting good at it takes hundreds of hours...so dont expect to look like the youtube pros for your rental!
/ How hard is it to learn to use a rental mini-excavator? #56
Prior to this excavator this summer, I'd never run one. It took me just an hour to operate this Kubota KX080. I pulled 15 roots in 8 hours.
I would think a 080 to be well into the 'midi' category. Moving one this size is not in the realm of your standard 2 axel 8k trailer? You would have to check and see what delivery and pickup costs? I ran a Kubota 035 recently and there is a little learning curve. I didn't do anything but play, though.
/ How hard is it to learn to use a rental mini-excavator? #57
I would never ever allow a child or pet to ride on any sort of machinery, whether it be an excavator or a tractor. Yeah, I know many/most of us did when we were kids and made it OK, but all it takes is just that one time and I'd just as soon it not be on my watch. They're just too squirmy/fidgety and unpredictable and it only takes a couple seconds for irreparable harm to be done.
/ How hard is it to learn to use a rental mini-excavator? #58
I rented one about 4 times. The first time the guy showed me how it worked. After about 15 minutes of playing with it I was good enough to do the work I wanted. If you can operate a tractor thew Mini X will be no problem.
You can do a LOT of work in a short time with them.
/ How hard is it to learn to use a rental mini-excavator? #59
Don't do what I did. My neighbor (in Damascus MD so some of you will guess who I'm talking about) saw me moving big stumps that had already been pushed out with a JD 655 loader. I have a JD 2038r so he came over and told me to use the mini x behind his house. He's a big ag farmer and has a LOT of extremely large equipment. It was close to his house so I asked him to move it away. He said he didn't know how to run it. I said how long have you owned it, he said 19 years. I said you've owned it that long and have no idea how to use it?! He said they don't let me run the equipment, all I know is there's a lever on the left side of the seat that makes everything work. He said "just get in it and you'll figure it out".
So I figured out how to move it without hitting his house and went next door to my 15 acres. I know this thread is about "figuring it out" but I had to use it really slowly because nothing made sense to me as far as the controls went. Long story short, I used that thing for 8 hours going up and down hills. Progress was extremely slow. Guess why...I was using it spun around in reverse!!!! When I pulled on the levers, the mini x would go forward, and all the turning was counter intuitive. The next day I accidentally figured it out, and did the same amount of work in two hours. Moral...make sure your spun in the right direction!
/ How hard is it to learn to use a rental mini-excavator? #60
You tube it. The only way to learn is just do it. Don’t have great expectations for a mini-ex to do any heavy duty stump pulling. Get the biggest excavator you can.
CASE TR270 SKID STEER (A62129)
CASE TR270 SKID...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Giyi GY-TB47 Forklift Telescopic Boom (A60463)
Giyi GY-TB47...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2018 Hyundai Robex 35 (A60462)
2018 Hyundai Robex...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
