Cast iron repair
/ Cast iron repair
interesting thread. what size or swing? is the saw, 17" or greater? sounds worth restoring the vintage machine
This one is 32", which is huge by modern hobbyist standards, but actually not one of the larger industrial-scale bandsaws Crescent made at that time. Their standard line went to 36", with a 38" HD option.
They or Tannewitz actually made some larger saws, into the mid-40-inch range, but they all had to be built into the factory floor, essentially over a pit for the lower wheel, to keep the saw table height at a usable level for an operator.
This isn't my first bandsaw, or even my tenth piece of vintage equipment, I used to have a whole shop full of 1000+ lb. vintage machinery from early 1900's. Right now, most of my shop is 1940's industrial and commercial models, more by coincidence than design.
Thank you for the explanation. I've done some foundary work, and went to bed after reading on your project and got to wondering how they could cast that wheel and keep the outer flange in one piece, much less keep it round. Banding a steel rim to affix to cast spokes does make a whole lot more sense.
In fact, as I look at your original wheel is it possible that the outer band was originally riveted to the spokes?
I'll have to get a closer look at the original. The literature from Crescent claims their wheels are cast as one piece, and then the outer rim turned (both OD and ID shoulders) true, before balancing. So, if we believe their marketing literature, that original with the huge missing section should be one piece.
The replacement is of unknown brand, it could be Tannewitz, Colladay, Oliver... really anyone making 32-inch bandsaws 100 years ago. I believe that wheel is two piece, an outer steel hoop shrunk and welded onto a cast spoke and narrow rim wheel. Essentially, cast wheel, face and turn hub, then turn OD to accept a steel hoop. Weld hoop, heat to expand, and slip onto wheel, fixture in place while it cools and shrinks, then tack weld a dozen spots.
Bottom line is if this is a project that matters, I would take both wheels down to your local Foundary and have a chat with them.
Philly used to be filled with foundries, but I don't think there are any left. There are some in Lancaster, who specialize more in agricultural stuff and fireplace doors, but I have had them make machine parts before. I don't think they're equipped to turn a 32" wheel, though... so we're talking foundry plus separate machine shop. Probably a few dozen Benjamin's for just this one part... and I already have another bandsaw. Tough call.
I'd go with your third option have a blacksmith cast a new wheel and shrink a new wheel to it. Or most any machine shop could fabricate you a new wheel out of steel.
I work with machine shops on a pretty daily basis, so I guess I could ask one about making a new part in steel. It would look a little odd having a clean machined wheel totally open and visible on this cast antique, but it certainly would be functional! Right now, I'm leaning toward having someone spray weld this wheel to build it back up, then let my machine shop re-turn the rim to true it up after welding.
/ Cast iron repair #22
whoa, that's colossal. assume you can find the blades at a specialty supplier. i understand now your reasoning for restoring it's use. regards
/ Cast iron repair
Blades are no problem. There are many places that stock coils of all common widths and tooth configurations, and I just call them up, specify the loop length I require, and they weld it up and mail it out. The only down side of 16' blades over 10' blades is cost, and how awkward they become to handle, as they get larger.
/ Cast iron repair #24
sounds like things are in place. that industrial size certainly overshadows my Grizzly 17", but i'm well satisfied. a 16' blade is something to observe, let us know the outcome of repair, regards
/ Cast iron repair #25
That's what I was wondering. It's just trivia, but deducing how the old timers made their parts is a fascination in itself. Even if your original wheel is one piece, I doubt that the foundry's master pattern was a single piece. Pattern models are usually buit up in pieces and then assembled. It wouldn't be a surprise if the pattern was of wood riveted to a steel hoop.
When the foundry uses that pattern to make the mold to cast the part, a successful casting will naturally reproduce all the surface features...including any welding and rivet heads on the pattern piece.
rScotty
/ Cast iron repair
Been working on another project all day, stuck at the computer. But will make it out to the shop tonight, if only to inspect the original wheel and get some better photos of it. Like you, I'm curious.
Most of the machines in my prior shop came from foundry pattern shops, as they had the best and biggest equipment made, at the time. There was a period 20 years ago, when all the foundries were closing, where you could have 24" planers, 26" jointers, and 16" table saws from Tannewitz, Oliver, and Colladay for the cost of moving them. Most came with three-phase motors, and I had a 3-phase generator, but eventually converted each to single phase. This bandsaw is the last of the "real old" machines I had 20 years ago, the rest were sold off to make room in the shop for working on cars and tractors.
If anyone thinks this little bandsaw is big, you should've seen my table saw! It weighed in at just a little over 2200 lb., the motor itself weighed 400 lb. The original power source was a steam engine-powered line shaft, later converted to run off a Ford flathead out of a model T. When it bought it, it was running off a 3-phase motor from the 1950's, but I repowered it with a more proper single phase 5-hp motor from Century, all turn of the century stuff. I think that saw was made around 1902.
Makers of machinery cared so much less about human life, back then. This band saw has no guards on the wheels:
/ Cast iron repair #27
It was a great era. I wonder what we will find of equal interest to preserve from today's manufacturing?
The largest band saw - by far - that I've encountered was at an old WWII warplane factory in Los Angeles. This was in the early 1970's, where I spent a couple of winters escaping from the snow and learning about craftsmanship, endless rain, and boat-building.
Inside that old building were some three dozen builders of 30 to 40 foot cruising sailboats. All sorts of different designs. Each buider rented enough space to construct their peculiar version of a sailboat to see the world. Most worked days and built at night. So the days were quiet and the nights full of activity.
In the center of the building was the BANDSAW which had been restored by some previoius boat builder. It was two stories tall. The blade came down through a hole in the ceiling and vanished upstairs though another. Very handy for long planks and for tapering wooden masts.
rScotty
/ Cast iron repair
Was it a tilting bandsaw, aka "ship saw"? Crescent made some of them, I think Tannewitz made more in the larger sizes. I remember seeing a documentary on one as large as you describe, ran a blade that must've been something like 4-6 inches wide!
Got tied up working on an air compressor project tonight, sort of re-doing my entire shop air dryer and distribution setup, which meant the figuring of dozens of new fittings, pipe, etc. Ended up putting it all into 3D CAD and doing up a full BOM, going to try to pull this one off without the buckets of extra fittings I normally have on hand for jobs like this. Buy only what you need, use only what you buy... or at least that's what I'm going to try!
/ Cast iron repair #29
Is it Solid Works? I've still got a copy of that CAD that I learned just to prove to myself that I could... and to keep the youngsters at bay.
But at heart I'm still a pencil sketcher.
Well, my hat is off to you buying just what you need. It is an admirable goal. I'm not there yet. I'm still at the stage of "....if it looks like I might need it, into the shopping cart it goes." and trying to wean myself from buying two of everything...just in case.
My intent is always to return the unused fittings, but that is just the intention. The reality is that returns rarely happen . Besides, even though I don't really need a spare 4" brass valve - much less two of them - where would I ever find them at that price again? And look how beautiful they are!
Yes, that huge bandsaw table did look like it could be tilted. But we never did. It would be a massive job to tilt a table that large. I don't remember the measurements, but it had to be 20 feet long and perhaps 4 or 5 wide. I'm thinking the blade was not quite that thick.... maybe 3"? I'm afraid it has been too many years.
When we turned it on, the relays would bang home, and the whole building would give a shake. Then the floor would sort of quiver as it gained speed. But once up to speed, it ran remarkably smoothly, quiet, and true. Very precise.
rScotty
/ Cast iron repair #30
good thread. unfortunately, pattern makers, like tool & die, are rare these days
/ Cast iron repair
Yep, SW 2024. I have to keep current, as I use it to support my business. Learned on a drawing board, and worked as a draftsman to help put myself through college. While there, I started doing my first 3D CAD (MiniCAD?), and started doing 3D renderings for large jobs at the architect's firm where I was moonlighting. Then followed 20 years of daily AutoCAD 2D, then 3D, Mechanical Desktop, and starting ca.2000... SolidWorks!
lol... you and I are cut from the same cloth, brother! I built up the BOM for this particular job, and then going through my drawers of leftovers from past jobs, was able to cross off a full half of it! I'm not only trying to buy only what I need, but also cutting down my own stock, in the process. I'm tired of all the material I store from all of these projects taking up too much of my shop space! It's also a burden of time to keep and sort it all.
I used to always want to have all parts and materials on-hand, extra fittings, extra valves, etc. But that's back when every "one short" situation on a $0.98 copper elbow meant another hour round-trip to Lowes Depot. Now, I can have the damn thing here in 12 hours from McMaster-Carr, if I really need it. So, I'm dipping into my own "contractors pack" bags of 3/4 and 1/2 inch tees, elbows, and threaded fittings, thinning the stock a bit.
Oh, you're in for a treat, rScotty! I didn't mean tilting the table! The ship saws tilt the whole saw! And yes, some of them are massive, but here's a little 36 inch version from Crescent:
These saws are made to make complex bevel rips on ships keels, changing the bevel angle as the keel runs from fore to aft in the boat, hence their nickname as "ships saws". They are usually run by at least 2-3 men, as you need an extra man to turn that hand crank on the right side of the table, which moves the whole upper saw arm. I think the larger ones are better balanced than this example, although even this "little" one is 8 feet tall and 2000 lb., and carries a 19 foot long blade.
Blade was probably a lot longer than you remember, on a monster that tall. What was the wheel size / throat depth? You eat up a lot of length on big wheels, L = 2*(pi*r + H), where H is working height. Blades even on these big boys are not that thick, probably less than 1/8" with teeth set for a kerf wider than blade.
2015 Isuzu NPR 16ft. Box Truck (A61568)
2015 Isuzu NPR...
BUNDLE OF 4"X RANDOM LENGTHS RED OAK FLOORING (A62131)
BUNDLE OF 4"X...
2012 Sun Coast Trailers T/A 12ft Enclosed Trailer (A61569)
2012 Sun Coast...
New/Unused Wolverine Quick Attach Auger (A61166)
New/Unused...
2021John Deere 331G Compact Track Loader (A61166)
2021John Deere...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
