5145 and a ditch bank flail mower
   / 5145 and a ditch bank flail mower #1
confederatemule
I have a 5145 with one set of factory installed rear hydraulic ports. The dealer connected the hydraulic hoses for the Grapple to these ports. It works great.
I now have a ditch bank flail mower. It came with a two lever control valve. One lever has a float function.
My question is; where should I connect to the tractor hydraulic system to get hydraulic fluid to and from the control valve?
I don't want to loose the grapple or loader function while I am operating the flail mower.
Thanks for any help
Mule
   / 5145 and a ditch bank flail mower #2
What kind of ditch mower did you get? I can look at my 5145 later and see what I can find to help with your question
   / 5145 and a ditch bank flail mower #3
Wondering if you could T into lines for rear remote?
I got a FH-AGF140 Ditch Bank Flail Mower from Betstco. The hydraulic control valve that came with the mower is a Wolverine by Prince MFG. CORP. model MB21GB5C1.
   / 5145 and a ditch bank flail mower #6
Thanks for any help
Mule
You have no choice but to use those ports unless you pony up the money for another valve or use a splitter
You can not simply T into the lines on an open center tractor. If you T into the remote connection lines both the grapple and mower will function at the same time unless you buy a splitter but they come with their own set of issues
   / 5145 and a ditch bank flail mower #7
there are two options that i know of:
1. the factory 2nd remote kit.
2. a diverter block where you can have as many outlets as you have space for but only use 1 at a time. the stock control lever controls the remote and you have a switch to select which remote outlet you want to use.
you can also install a W.R. Long 3rd function kit and release the rear remote from operating the 3rd function.
   / 5145 and a ditch bank flail mower #8
With just one remote you are not going to be able to use the loader/grapple and ditch bank mower at the same time. Even with multiple remotes you will not be able to use them at the same time.
With just a bit over 8 gpm on an open center system with very carefull modulation of your loader valve you may be able to lift and curl at the same time. But if you try and do something with your rear remote at the same time nothing will happen as all your flow is going to the loader till it's maxed out or you release the valves for it.
One option would be adding a diverter valve to your rear remote, run one pair of the outlets to the grapple and on the other pair select one port to supply the valve on your flail mower, take the return from that valve directly to the tractor reservoir. Plug the other diverter port.
Depending on how you plumb and wire the diverter when the remote valve is operated and the diverter is not energized it could run your grapple as it does now. With the diverter energized and the remote locked/tied on the flow would pass through the mowers valve waiting for your valve operations on that valve.
Another thing to be aware of is that with the flow going out to the "new" remote valves your 3 point would not work.
On my Branson with 3 rear remotes none of them have a float position so my ditch bank flail will not float on the pivot I have to watch it carefully to maintain a level cut especially when offset and down in a ditch.
   / 5145 and a ditch bank flail mower #9
I do not believe you are correct (if i understand your post) with the open center all of the fluid is bypassing all of the time until a valve diverts the fluid to a use. as to the 8gpm max flow i have a hard time using more than 2 functions at a time because of dexterity and attention span not limited by the GPM
   / 5145 and a ditch bank flail mower #10
Depending on the valve and how fine the notching is in the valve, decides how easy it is to modulate. So yes if you can smoothly and gently modulate those valves on a moving tractor you can do more then one function at a time. Of course as you operate the functions it also changes the back pressure on the other operators. More flow rating makes it easier to modulate multiple valves.
According to the dealer where I bought the tractor a second remote kit is not available.
In reality I can operate only one function at a time, but I dn't want to have to switch hoses to be able to go from one control to another.
   / 5145 and a ditch bank flail mower #12
Thanks for any help
Mule
I'm not familiar with the 5145 so I don't know if this will help.
I use the 3rd function valve for the grapple to operate my ditch bank flail mower. I don't need to use both the grapple and ditch mower at the same time. I ran hoses from the 3rd function valve to operate the flail and just swap the hydraulic connectors.
My tractor already has 3 rear remotes, two of which are needed for the T&T kit, which leaves just one spare. The flail needs 2, so I used the 3rd function valve to add the fourth.
I had the parts laying around, so I added an extra OEM break away connector body to the stack. It really isn't necessary though, since the hoses could be connected directly to the flail.
   / 5145 and a ditch bank flail mower #13
View attachment 853775 View attachment 853774
View attachment 853773 View attachment 853784
good lord, do you even use your tractor?
its too shinny, please rub some dirt on it
   / 5145 and a ditch bank flail mower #14
I have 2 rear remotes on my 5145. I should be back home this weekend. I will try to get picture of connections
   / 5145 and a ditch bank flail mower #15
I am guessing their is possibly no preassembled kit like many manufacturers sell but it sounds like your dealer is lazy and doesn’t want to look up everything needed.
   / 5145 and a ditch bank flail mower #17
Ah, the weekend warriors. He would curl up in a corner if he saw my tractor right now.
Those pics were taken the day after the dealer delivered it. I wish it still looked that way now.
   / 5145 and a ditch bank flail mower #19
Please do that, if you have time.
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2006 Freightliner Auger Truck (A56438)
2006 Freightliner...
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2018 PRINOTH...
2004 CATERPILLAR 320C L EXCAVATOR (A60429)
2004 CATERPILLAR...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2007 FREIGHTLINER...
