5145 and a ditch bank flail mower
   / 5145 and a ditch bank flail mower
there are two options that i know of:
1. the factory 2nd remote kit.
2. a diverter block where you can have as many outlets as you have space for but only use 1 at a time. the stock control lever controls the remote and you have a switch to select which remote outlet you want to use.
you can also install a W.R. Long 3rd function kit and release the rear remote from operating the 3rd function.
According to the dealer where I bought the tractor a second remote kit is not available.
In reality I can operate only one function at a time, but I dn't want to have to switch hoses to be able to go from one control to another.
   / 5145 and a ditch bank flail mower #12
I have a 5145 with one set of factory installed rear hydraulic ports. The dealer connected the hydraulic hoses for the Grapple to these ports. It works great.
I now have a ditch bank flail mower. It came with a two lever control valve. One lever has a float function.
My question is; where should I connect to the tractor hydraulic system to get hydraulic fluid to and from the control valve?
I don't want to loose the grapple or loader function while I am operating the flail mower.
Thanks for any help
Mule
I'm not familiar with the 5145 so I don't know if this will help.
I use the 3rd function valve for the grapple to operate my ditch bank flail mower. I don't need to use both the grapple and ditch mower at the same time. I ran hoses from the 3rd function valve to operate the flail and just swap the hydraulic connectors.
My tractor already has 3 rear remotes, two of which are needed for the T&T kit, which leaves just one spare. The flail needs 2, so I used the 3rd function valve to add the fourth.
I had the parts laying around, so I added an extra OEM break away connector body to the stack. It really isn't necessary though, since the hoses could be connected directly to the flail.
   / 5145 and a ditch bank flail mower #13
View attachment 853775 View attachment 853774
View attachment 853773 View attachment 853784
good lord, do you even use your tractor?
its too shinny, please rub some dirt on it
   / 5145 and a ditch bank flail mower #14
I have 2 rear remotes on my 5145. I should be back home this weekend. I will try to get picture of connections
   / 5145 and a ditch bank flail mower #15
I am guessing their is possibly no preassembled kit like many manufacturers sell but it sounds like your dealer is lazy and doesn’t want to look up everything needed.
   / 5145 and a ditch bank flail mower #17
Ah, the weekend warriors. He would curl up in a corner if he saw my tractor right now.
Those pics were taken the day after the dealer delivered it. I wish it still looked that way now.
   / 5145 and a ditch bank flail mower #19
Please do that, if you have time.
toro turf sweeper (A50324)
toro turf sweeper...
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
