Joel/ak
- Joined
- Mar 22, 2022
- Messages
- 1,456
- Tractor
- Bobcat 324
Here's one. The drive ran at 6k psi, rollers ran at 2500psi.
Agreed about the weird stuff. Air start units. Deicing equipment. Tugs. Mobil stairs. Catering trucks.Many oddball pieces of gear. Airports are notorious for weird crap. Whenever our sales rep for TLD would make a visit, I would grab him and ask WTF they were thinking on designing this crap.
Schematics on some were in French (didn't help much).
I definitely hired good fabricators and hydraulic mechanics.
I would pay to see a 500+# person riding that...wouldn't you?Agreed about the weird stuff. Air start units. Deicing equipment. Tugs. Mobil stairs. Catering trucks.
I posted a video of this a few days ago that I came across. I used to run two of these Wheelhorse Airhorse movers. Great fun. Great machine!
Wow, would rather have worked on that vs the fmc b1200's and our T750Agreed about the weird stuff. Air start units. Deicing equipment. Tugs. Mobil stairs. Catering trucks.
It can hold them no problem. That yellow fork is several hundred pounds.I would pay to see a 500+# person riding that...wouldn't you?![]()
WOW! Those are beasts! Had to look them up.Wow, would rather have worked on that vs the fmc b1200's and our T750
Odd? Yes but functional. I've found that airport mechanics are pretty dang good and creative.Thinking about it, a lot of folks would call my PowerTrac PT425 an odd machine.![]()
We had two air start units. One was on an early 50's truck chassis. It was a 6 cylinder detroit diesel. The other was on a late 60's truck chassis. It was a v8 detroit.Odd? Yes but functional. I've found that airport mechanics are pretty dang good and creative.
Our tractors were beasts. Alot of airlines would rent our gear. Our b1200's (had 4 of them) were 120,000lbs and the T750 was 150,000lbs. They would move anything.
Airstarts are a whole nother beast. Had a new rheinmetal. Jet engine that spun at 25k rpm. Parts were expensive and crappy fuel mileage. Went through 100 gal of jet A in 2 hours. Yelled at alot of pilots cuz they wanted to dick the dog taking their time for a start
I'm not sure if this counts, but at one time I worked in a furniture mill.
We had one machine called the "RF Machine" or "Radio Frequency Machine". It was a big microwave for gluing wood together. Whatever they were laminating, they'd run glue along the edges then push anywhere from one table top to a whole pile of legs into the machine at once. It would press the pieces together and hit them with the microwave for about a minute at which point it would shove a sticky mess out to be thrown on pallets with sawdust thrown between to keep them from sticking. Thinking back, a lot of manual labor.
Anyway, the interesting part of the machine was on the back side, outside of the machine, there was an ordinary florescent light tube sitting on a wire rack. No wires going to the tube. The RF power from the machine lit up the tube without wires and the person tailing the machine knew it was turned
A number of years ago I was working on an electric forklift in Cleveland Ohio. It had stopped operating and when I tested it found a couple components burned out. I made the repair and put the unit back in service after testing the operation . A few days later I got a call the machine had broken down again, back out, test, same problem. Repaired and tested back in service. This happened a couple more times and I removed the unit for more complete testing and cleaning before returning. One day later it had broken down again. After asking where it was broken the owners stated it always quit next to the "dryer" turns out it was getting blasted by electrical interference. I added shielding to the unit and never had another problem with it. I serviced equipment at the same company for a few more years until they moved their opperation.I'm not sure if this counts, but at one time I worked in a furniture mill.
Anyway, the interesting part of the machine was on the back side, outside of the machine, there was an ordinary florescent light tube sitting on a wire rack. No wires going to the tube. The RF power from the machine lit up the tube without wires and the person tailing the machine knew it was turned on.
I worked on the WABCO electricsView attachment 850697
CAT 631 Probably the funnest off road machine, 500+ HP, hauls 30+ yards and goes 35MPH. When you are riding you get to look down into the cabs of dump trucks and tractor trailers.
Nice stuff. I worked on and repaired EIMCO loaders and dozers looke similar to the dozer you posted.I have deep connections with forestry industry, but never ever have seen such tractor as topic starter have posted.
I thought this fancy looking is something:
Track Tractor TDT-55 (Saldus) - redzet.lv
This track tractor is used in forestry, particularly logging of timber, building and packaging timber piles, loading, as well as for groundbreaking and road...www.redzet.eu
Just something from my album
5 axis CNC for chairs
Nothing special, just big
Once had to hire this. 3 guys 1 day worked on assembley. Actual lift was 30 minutes
While ago have sold sanding machine for CLT panels. 10 FT wide
Take in entire wall and work with 5 m/min
They could be a challenge. Simple design, not easy to keep in adjustmentMy brother owned a Bell for many years in his small land clearing business. He said only one of his employees could properly operate it. Odd looking machine.
