What is the oddest machine you have worked on or operated
/ What is the oddest machine you have worked on or operated #1
Dennis Mohn
Ohio
Steiner 430 max, cub cadet 48in. self propelled walk behind
A number of years ago I worked for a John Deere dealer in central Pa. It was on the commercial equipment side and I worked with a lot of forestry equipment. One of the units was a Bell feller buncher. It was three wheeled , hydrostatic drive, and looked like the body for an old helicopter. It was made in South Africa and even with correct part numbers you were never sure what you might receive. And when it came to operating , if the linkage was out of adjustment which they always were , it was like trying to control the wildest animal you could think of. I had one parked between to new JD machines and when I went to move the Bell it almost ran into the two new machines, I was a busy somebody for a few seconds.
/ What is the oddest machine you have worked on or operated #2
Not sure if it counts but I used a reconstructed fish wheel, used it in '96(?) but not sure when it was originally built sometime early 1900's.
whats a fishweel?
/ What is the oddest machine you have worked on or operated #5
I had to wire in a early 1930’s era coffee roaster that was made in germany. All controls were disassembled and tossed into box. Everything printed in german. Actually had **** cross symbols forged into steel, though thew were mostly ground off. Absolutely no instructions existed. Everyone, including 3 state electrical inspectors were stumped. We finally got it going thru trial and error.
but it was eary working on that machine due to its history.
/ What is the oddest machine you have worked on or operated #8
A self propelled rail car ramp for loading autos onto rail cars.
It looked like any other ramp, except there was a hatch between the ramps that you opened up, hopped in, and drove a little tractor-like machine. You'd raise up the legs, lower the ramp, and you looked like a parade float driving through town to get to another siding.
You'd pull onto the tracks at a road crossing, and drive up to the car, raise the ramps with some cable system I forget how it operated, locked it down, set the feet, hopped out and closed the hatch.
/ What is the oddest machine you have worked on or operated #9
I worked on one of these GE engines. I thought it was built in the 40s.
/ What is the oddest machine you have worked on or operated #10
travel lift. It's like a mobile gantry crane for lifting boats in slings out of the water. The one I occasionally operated was much older, smaller, and imagine more quirky than the one I found off the googler.
/ What is the oddest machine you have worked on or operated #12
Back in 1966 did a tune up on a home made
tractor with a model a Ford 4 cylinder engine
new plugs, points, capacitor, rotor, dist cap,
plug wires, fan belt, change oil, radiator juice
also worked on a large wall clock similar to this:
willy
/ What is the oddest machine you have worked on or operated #13
Zone rated offshore oilfield equipment. Engine driven hydraulic power packs in explosive proof form, positive pressure cab full of my computer equipment with multiple interchangable winch drums with different IPS steel cables approx. 20,000 feet long for different situations to lower tools for data collection or mechanical services in oil wells. And associated equipment to let that cable into the well under up to 15000 psi of well pressure. Some really interesting and unique equipment to run, transport, troubleshoot and fix.
/ What is the oddest machine you have worked on or operated #14
I'm not sure if this counts, but at one time I worked in a furniture mill.
We had one machine called the "RF Machine" or "Radio Frequency Machine". It was a big microwave for gluing wood together. Whatever they were laminating, they'd run glue along the edges then push anywhere from one table top to a whole pile of legs into the machine at once. It would press the pieces together and hit them with the microwave for about a minute at which point it would shove a sticky mess out to be thrown on pallets with sawdust thrown between to keep them from sticking. Thinking back, a lot of manual labor.
Anyway, the interesting part of the machine was on the back side, outside of the machine, there was an ordinary florescent light tube sitting on a wire rack. No wires going to the tube. The RF power from the machine lit up the tube without wires and the person tailing the machine knew it was turned on.
/ What is the oddest machine you have worked on or operated #15
CAT 631 Probably the funnest off road machine, 500+ HP, hauls 30+ yards and goes 35MPH. When you are riding you get to look down into the cabs of dump trucks and tractor trailers.
/ What is the oddest machine you have worked on or operated #16
Never driven one but it looks like a wild ride, and a kidney buster!
/ What is the oddest machine you have worked on or operated #18
I once worked on a 24 (or 27, I can't recall) yard bucket on a payloader. Didn't get a pic of the machine but each tire was 13ft tall. This was many years ago and it worked in a powder basin coal mine.
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
2011 Case IH Magnum 315 Tractor (A64047)
2011 Case IH...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
Polaris Ranger 1000 Side by Side (A64047)
Polaris Ranger...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
UNUSED 2026 INDUSTRIAS AMERICA 7014R 7'X14' DUMP T (A62130)
UNUSED 2026...
