/ Harbor Freight Tools that don't suck #15,651
most of this is common sense, interesting HF employee comments on quality
I like the one idea, put an expensive item in your outbox and let it sit there for awhile.
HF sees that and apparently may send you a 25% off coupon (wish you were back stuff) soon thereafter to
motivate you to buy.
worth a try...
I do that with Amazon, sometimes it works, sometimes not. I have a 639.00 tree pusher in my cart for 2 weeks and nothing so far. Can’t use it until the spring so not a big deal if I have to pay full price!🌲🌲🌲
/ Harbor Freight Tools that don't suck #15,652
I did buy the little greenhouse, easy purchase, did see their branding of pumps, never heard of that name
will report back when greenhouse built
/ Harbor Freight Tools that don't suck #15,653
Try https://www.camelcamelcamel.com/ for monitoring Amazon prices. See history of prices. Set an alert at any price you wish and get an email if met.
/ Harbor Freight Tools that don't suck #15,654
Agree!!!
I've had uneven luck buying welding wire at Amazon that is apparently customer returns or shipping damage, but the price makes it attractive and returns are no-hassle. I'm cheap. A chunk chipped out of the side of the spool for example, won't affect usability.
Here's something scheduled to arrive here tomorrow. I paid $10.97. I would have paid $21.99 (price today, I just checked) - if I ordered at full price when starting a project, instead of waiting for a camelcamelcamel deal to come along.
Copied from their email:
3rd Party Used Price History​
Amazon price history chart for INETUB BA71TGS .030-Inch on 2-Pound Spool Carbon Steel Gasless Flux Cored Welding Wire
$10.97 Prime
Price when tracked (Apr 02, 2023, PDT):
$14.98
Desired price:
$12.50
/ Harbor Freight Tools that don't suck #15,655
I’ve been eyeing that greenhouse, but haven’t been able to figure out how to anchor it to keep the wind from blowing it. The material looks lightweight. Please post back after you get it built with any ideas for anchoring and reinforcing it.
/ Harbor Freight Tools that don't suck #15,656
My 8750 Predator inverter generator let me down. The company that makes it uses a LiFePO4 battery that just isn't right for a generator in cold weather. I think it didn't have the voltage needed to open the fuel cutoff solenoid so it wouldn't start. Neither pull starting or with the battery (that quickly died). I ended up jump starting it. I've since removed the solenoid and will replace the battery with a lead acid battery once I have the time to make a battery box.
/ Harbor Freight Tools that don't suck #15,657
What id do is build a raised garden bed slightly smaller than green house specs allowing a walkway in between beds build the greenhouse on top of and along sides of wooden garden bed probably 2-3 separate ones each side and back wall? figuring out how you want to secure it to the garden bed and enjoy not growing vegetables on your hands and knees all summer with a pretty stable and secure greenhouse? IMHO even some cheaply built Chinese junk can be made pretty useful and durable with a little ingenuity.
/ Harbor Freight Tools that don't suck #15,658
Thanks so much for the tip. I found the next size pusher for 699.00 which is 100.00 off, going to purchase that one thanks to you. I owe you bro!☮️✌🏻
/ Harbor Freight Tools that don't suck #15,659
I was amazed at the diminished performance of the lithium in cold weather. I installed one in my sxs last summer and it worked great in the warm weather but once it got cold it would almost nothing till about the 3rd try or after turning the headlights on for a minute or two. Then when it got real cold I had/have to use my jump box for the first start and sometimes after a long period of being off. My jump box is an older gell type lead acid, larger and heavier booster pak.
iDrive TDS-2010H...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2008 Mercury Milan Sedan (A59231)
2008 Mercury Milan...
2015 Freightliner Coronado 122SD T/A Day Cab Truck Tractor (A60352)
2015 Freightliner...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
