Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #15,641
Are the Horrible Freight “Pittsburgh Jumbo Socket sets” worth buying?
94% positive reviews, but the 1 star reviews said the ratchet broke (which is what you’d expect).
Cant say about current production but the 3/4” set I bought in the early 80s is still going strong. No breakage even when I used them on impact guns. Had a 6’ cheater pipe on the ratchet trying to get a bushhog blade bolt loose without a problem.
   / Harbor Freight Tools that don't suck #15,642
My brother got their 3/4" breaker bar last year to break tractor lugnuts (couldn't find the rest of his kit, but we found the right socket), put a 6' pipe on the thing and it worked fine, I think it was a ratcheting breaker bar or something with course teeth...
   / Harbor Freight Tools that don't suck #15,643
My problem with HF coupons is that they're digital only, they won't accept a print-out of one. Not gonna go out and buy a smart phone just so I can save 10% on something I don't really need or to get a free 5 in 1 screwdriver.
I print out coupons and my local Harber Freight accepts them.
   / Harbor Freight Tools that don't suck #15,644
Were you really cranking on it when it broke?
How has the new one held up?m
Mine didn't break while torqueing down a bolt. The ratchet assembly came apart and would not change the direction of the socket. I do admit it is not the highest quality tool but I'm not using it everyday. I only use when something on my tractor need to come apart or tightened. If I really need to torque something down I use the ratchet to get it tight and then use the breaker bar to finish tightening the bolt.
My point was that they have a lifetime warranty, so if it breaks I can get it replaced. I couldn't justify the price of a good 1" ratchet set for the amount of times I use it.
   / Harbor Freight Tools that don't suck #15,645
Not sure if it sucks because I haven't used it yet, but I have high hopes. Going to use it to cut the 6x6s and 4x6s for my sawmill base tomorrow. Will edit the post if it does suck. Not bad for $135($75 for beam cutter and $60 for used worm drive)
   / Harbor Freight Tools that don't suck #15,646
most of this is common sense, interesting HF employee comments on quality
I like the one idea, put an expensive item in your outbox and let it sit there for awhile.
HF sees that and apparently may send you a 25% off coupon (wish you were back stuff) soon thereafter to
motivate you to buy.
worth a try...
   / Harbor Freight Tools that don't suck #15,647
has anyone tried HF's cheap greenhouse?
my seeds are in, and I have the itch.....
it seems to get good marks for basically a simple structure
   / Harbor Freight Tools that don't suck #15,648
So I used the Beam cutter. Works pretty well. A little rough where the chain comes up out of the wood but nothing that a razor blade and a bit of sanding couldn't take care of if it really mattered.
   / Harbor Freight Tools that don't suck #15,649
I have one of those, too.
Then I went with an 8&1/4” worm drive and just cut them in 2 passes.
Yes, you have to flip the beam, but I liked the cut quality.
   / Harbor Freight Tools that don't suck #15,650
Yeah, to be honest I used my regular worm drive to cut the 6x6s because the kerf would have screwed me with this beam saw (needed 4 30" blocks and I had a 10'er).
534 (A52708)
534 (A52708)
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
Skid Steer 66in Skeleton Bucket (New/Unused) (A59225)
Skid Steer 66in...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
2016 Morbark Chipper (A55787)
2016 Morbark...
