Calling all residential electricians
/ Calling all residential electricians #1
Pixguy
Super Star Member
By the lake in NH & FL
2011 MF 2410 TLB
Hi all, I'm looking to add an outlet to the double switch plate I have in this toilet room so my wife can get in a nightlight. I knew I'm supposed to use a gfci outlet in a wet area so instead of adding in an old construction outlet below, I decided to put in the combo switch/outlet shown below. There's two sets of wires coming into the box, I don't have my volt meter here in Florida and the wires are 14/3 and a 14/2. It appears obvious to me that the 14/2 wire is power coming in and the 14/3 goes up to the light/fan. I followed the instructions but the gfi pops each time I turn power in.
What am I doing wrong?
/ Calling all residential electricians #2
That's not a 3-way switch, and the presence of a red wire (the 14/3) indicates it may well be a 3-way circuit. Is there another switch controlling that light?
Also you really don't need a GFCI there...
My $0.02
/ Calling all residential electricians #4
Also, looking at that gfci. I think you need to power the fan switch from the load side of the gfci, not the line side. Ive seen gfci issues before where you split off a line to the device that receives its neutral from a gfci.
My $0.02
The 3 wires lead up to the fan/light
Please explain to me a bit more
/ Calling all residential electricians #8
/ Calling all residential electricians #10
i think you may sharing the neutral with both the light, gfci and fan but not having all the power going through the gfci. My money would be to splice the 2 whites together with a tail to the line side of the GFCI plug. Then the fan and light are not on the GFCI, only the plug.
/ Calling all residential electricians #12
Rather than add a night light to the switch, I would change the overhead fixture. We have bathroom fan/light fixtures that include a night light. It is amazing how well a small night light in the ceiling fixture lights up the room.
Doug in SW IA
The incoming feed to the fan switch needs to be powered from the load side of the gfci. Right now it’s being powered by incoming line side
Winner.... Thanks
I tried this this am and all is good. I may decide just to add a receptacle below cuz it is an open inside bay.
Thanks all!
/ Calling all residential electricians #17
The reason it tripped was due to uneven load thru gfci. The neutral was running thru gfci, but the fan positive wire was not. Now that you rerouted fan feed, its all balanced.
Glad you got it fixed. But those lighted covers come in toggle and decora style. Just have to scroll thru site.
I see the decora highlight now but I'll pass at $28.48 with shipping. thanks again tho
After all that, I'm going to add a receptacle below instead of that funky plug combo. It just looks weird. Thanks all
2011 Kenworth T300 S/A 17ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
Bobcat SC72 (A64127)
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A64553)
2025 GIYI GY-PG72C...
New/Unused Wolverine Sickle Bar Mower (A65583)
New/Unused...
