Frost heave?
/ Frost heave? #1
gstrom99
Elite Member
Butler County, Iowa
Deere 855, Deere 530R zero turn, Allis Chalmers D17 III, Polaris Ranger, Deere 3032E (SIL's), Yamaha Timberwolf 250, Husky saws, H & H 10k and Carry-On trailers
I have (large) sliding doors on my pole barn, but I only need to open one of them. Every winter, the frost heave causes the door to bind and I find myself trying to dig out the door's path in the gravel. It's annoying and sometimes its frozen and I need my pick axe. Short of pouring a concrete pad (or replacing the thing with a roll-up), anyone have similar issues and/or solution(s)?
/ Frost heave? #2
What type of sliding door?
I have a similar problem on my shed. The ramp into the shed heaves and causes the door to stick.
In my case the door has adjustable rollers at the top that let me adjust the door a little higher.
/ Frost heave? #3
Raise the door track and screw on some round baler belting to act as a flexible seal. If there is ice or snow accumulation also blocking the door base, put some water softener salt in the track. Good for 20 deg & above. Or even put a heat tape down there.
/ Frost heave? #4
Similar situation without much of a solution. Pick axe or similar works best. Later today a mountain of snow will slide off the roof and stick tight to the doors, later freeze in place. Knowing the hard way that this is going to happen I opened the doors so I can plow the snow from in front of the doors from inside the barn I will still have to dig the doors out because they'll be snowed in in the open position but it's less work this way.
/ Frost heave? #5
One comment about salt. The barn doors here had a concrete pad poured (1907) up next to the stone and concrete foundation, with a path formed for the doors to slide. That groove would fill with snow, then water from the roof, and more snow. I always used an ice spade to free and clean it. There was plenty of space for the door, so frost heave didn't matter, keeping the track clean was more important. Someone decided salt was easier (2007). In 10yrs the pad in front subsided 6-8" making it unusable. Salt destroyed the soil structure underneath turning it to saturated mush. What was under the pad was just glacial till gravel. Today more likely there would be crushed limestone or something similar, so that whole scenario might turn out differently.
/ Frost heave?
They're just regular giant steel panel with 2x6 wood bracing 12' tall by 12' wide (each) doors. I've seen those "tracks" in poured concrete and don't want the accumulating water/ice issue. I've adjusted the top door tracks so there is pretty good space beneath it, but that seems to get smaller every winter. Other than a concrete footing and pad, there's no real/permanent solution - so I just gotta keep the space clear. I like the rubber belt idea, to try and keep it clear though.
I wonder how much a roll-up door conversion would cost? $10k I bet...
/ Frost heave? #7
Even highly "engineered" projects can go wrong. Six years ago our little college town extended the sidewalks out to well beyond the edge of town. Kind of nice for the town folk. Safe/flat place to walk/run - walk your dog.
Well - the following summer they found that all was not well. As our local temps hit +90F and above - these new sidewalks began to buckle. And not just a little. Every 50 feet or so - the walkway would buckle up at the expansion joint. Six to eight inches up.
I think they have it corrected now. Bigger and more expansion joints.
The entire project must have been somewhat embarrassing for somebody. It looked like a concrete roller coaster.
/ Frost heave? #8
pouring a footer and laying concrete blocks under the door makes that go away.
/ Frost heave?
I can do that... How deep should the footer be?
/ Frost heave? #11
Below frost level. Then put foam board over it. Frost will go down but not sideways.
I was going to suggest simply digging out the ground in front of, under, and in back of the door. Then replace it with good packing sand.
I agree sand. or fine gravel. Something well drained that cannot freeze.
/ Frost heave? #12
Not sure if its reasonable in your situation or not, but what about trimming the bottom of your door? I have a 4 inch gap between the door and the ground and it allows for frost movement as well as some snow accumulation.
/ Frost heave?
The top track is adjustable. I just don't like the big gap on the bottom - lets all sorts of snow to blow in. There is only a slight slope to the entrance ie: poor drainage - but I'm stuck with that, since they originally built the barn about 6 inches too low. I keep a corner opened up pretty good for the cat(s) to come and go.
/ Frost heave? #14
I have built a few wood in ground "tracks" for rolling doors.
They work well although extended periods of very cold weather will "pinch" the door to where it's a pushing match but never to the point where I couldn't operate the door.
You can see it's basically a pressure treated U (2x6) with a 2x4 ripped to the doors thickness plus 1/2". 3/4" would be better. You can see how these spacers are not continuous to allow rain water to pass through. I dug a "trough" about a couple of feet wide and deep under the "track" then filled to the finish grade with this local gravel.
/ Frost heave? #16
Frost heave:
/ Frost heave?
I have built a few wood in ground "tracks" for rolling doors.View attachment 848604
Thanks but, if I did something like that, it'd just be filled up with gravel/snow/ice in about a month.
/ Frost heave? #18
Yes, insulating foam under the door. Use 4" thick, and extend 2 feet either side of the door (inside and outside the barn - if not heated), and a little beyond the door travel (or around the posts). Put it down 6-7", and put 2-3" of your gravel or sand back over the foam. It will not heave after that.
A poured slab or concrete blocks as a threshold are only heave resistant if there is lots of well compacted clear stone with good drainage under it/them (and maybe insulation too). The insulation under the ground is more simple and low cost, and you can still grade the stone or sand above it.
/ Frost heave?
Good idea, and worth a try!
/ Frost heave?
This thread has me thinking about how heavy this dang door is (steel panels and 2x6 framework) and how it's getting harder and harder to slide it open, even when it's not hung up on the gravel. I only open one of the sliding doors anyway. I might just look into sealing up the one unused half and get a roll up door for the opening I use... Menards has one, for about $1200 - plus installation.
There is a (bigger) sliding door pair on the north end of the barn to use if needed (I rarely open those), and they work "okay".
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
CASE 610 Sprayer System 2000 Gallons (A63118)
CASE 610 Sprayer...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
