Tractor decision
/ Tractor decision #141
Hi, I’m new to this forum. I have 50 acres, 15 pasture, 35 wooded. We are starting construction on a new home, 1400 foot driveway. Right now I am focused on LS
MT347 cab hydro with bucket, plow, box blade, brush hog. Am I on the right track? Up until now I have only had garden tractors. Thnx, Barry
Hi Barry Not surewho makes LS but hummed and hard about buying a TYM or splashing out and getting a Kobutu or a name brand. Brought the TYM as it was a lot cheaper and had it for 4 years now with no iissues. Also hydro that I was worried about but find it excellent
/ Tractor decision #142
look at the Yanmar YT 347 (westfieldagandturf) great dealer easy to work with and not far away in western New York
/ Tractor decision #143
Funny.
I have a set of forks and use them a lot to move logs, steel, pallets of crap, etc. When we moved to our new house, the wife palletized everything, and I loaded the pallets into the semi with my tractor. When the new house was done and ready to move into, we brought the semi back, and I unloaded the pallets into the garage, at the front steps and behind the house at the lower level. According to a number of folks here, I shouldn't have them, nor do I need them.
The ground hornet risk and having a cab is real. About five years ago, when ramming around in my woods with the Kubota BX2380 that I had at the time, I ran over a log. I noticed the first wasp when it crawled behind my glasses. By the time it was done, I had been stung 17 times. Luckily, I am not allergic to bee stings but it took a few days to finally feel better. It would have killed my wife. But, again, I don't need a cab, according to some folks here.
I fear the ground hornet swarm. So far I have been fortunate.
If it ever occurred and I lived through it, I would probably sell my open station and get the cab.
/ Tractor decision #144
Doesn't mean his decision will be the best. I have 35 acres woods, 10 acres non wooded.
If I was worried about snow and the cold I probably would have gone with a cab but being in East Texas I elected not to bust glass and weather the heat.
I'm just the opposite: With the work I do, I'd surely bust up a cab in the woods on a regular basis. I'm in Vermont, but I can dress for the cold and snow. I might have risked a cab just for the AC if I lived in the south.
/ Tractor decision #145
Some are going to argue this to death and insist everyone needs pallet forks.
I have a grapple also and a bolt on hook on my bucket and a chain.
Forks are more of a necessity for those of us who work with logs or large bulky items like boulders, buckets of course perfect for loose or granular materials.
I love forks, especially with a log grapple mounted up top. A lifesaver at work.
If you have both, your tractor becomes a force to be reckoned with!
/ Tractor decision #146
LS makes their own and like TYM also make tractors for others.
/ Tractor decision #147
Funny.
Nobody says you don’t need a cab. The original poster wants a cab so it’s up to him. I don’t get some of you guys thinking everybody needs the same thing as everyone else has.
/ Tractor decision #148
I found the (Ironcraft 4k) forks to be useful. I have lots of trees to deal with. However, I got them initially to be able to unload deliveries off of trucks. Also use pallets to store my implements and attachments, easy to move around. Same with bulky or heavy supplies (fencing, stone, etc.)
I use my bucket more and will probably use the grapple more once I figure out which one I want.
/ Tractor decision #149
that's a nice-looking tractor!
/ Tractor decision #150
/ Tractor decision #151
I agree with earlier comment that about 1 hp per acre is a good size. Get the cab, you won’t regret it, the added weight is beneficial. Get cast wheels or wheel weights, in addition to fluid in the tires. Extra weight provides much needed stability on slopes. If you have any trees, get the grapple. These are recommendations based on my experience on 22 years of owning 70 acres of grassy and wooded hills in the mountains of western NC. I’m also retired. I have a set of pallet forks that I rarely use, although I have a grapple and hay spears.
Best of luck
No one makes a 2 horsepower tractor, and what good would it be anyhow? 😆
/ Tractor decision #152
Every property owner has different needs and every size tractor is beneficial in different ways. I have a John Deere 5075E cab tractor for big projects, a open station Deere 3320 CUT for smaller projects, and garden tractors and zero turns for mowing different terrain that I deal with. Every machine has its place and purpose.
/ Tractor decision #153
Some other benefits of multiple machines is that the hours you put on them are spread across them and you have some redundancy.
/ Tractor decision #154
pretty much have forks attached most of the time, so easy to wrap a synthetic sling round a tyne for lifting as well.
/ Tractor decision #155
I move a lot of trees around (fallen trees and cut trees for firewood) and I used to use the forks extensively. It also helps to move certain pieces of equipment around (implements or when I had to move my lathe) However, now I have the 4-in-1 bucket and that was a game changer for chores. I can grab logs like a grapple, move and sift dirt, plow snow, grade like a BB, move dirt like a dozer and not have to change anything. I even took out another lot of chain-link fencing just by grabbing it from the top and pulling it out. Last year I flattened and graded a new garden for the mrs with just the bucket
I'm a big cheerleader now for the 4 in 1 bucket. You can have that one item and do a lot of work.
Although tbh having a big bucket has taken some of the fun out of plowing because I get it done fast and in the cab with the heat on 🤣
/ Tractor decision #156
I have a purchased new, LS M2-25s open station with loader and in the last 2 years of ownership had zero problems and I really like the engineering, component selection, and creature comforts it possesses.
I also have a 65 HP Branson with cab and loader that I bought new in 2007 and haven't had any problems to speak of over the years. Between those extremes I have 4 45-50 hp older model tractors that are open station with no loader; 3 are Fords and one Case-IH.
If you are doing things out in the weather...moving snow or haying, the cab is the way to go. If you are doing anything else the open station is the best choice. If you do a lot of getting on and off with what you are doing, a tractor that supports that process is a necessity and open station is the ticket.
I am convinced that you can't be all things to everything you are planning to do with one machine. What I would suggest is to buy older tractors having the attributes that were akin to what you wanted to do.....buying older you can get more tractors for what you would spend on a new "single function" (more or less) new one.
On dealers, in 45+ years of owning my farm, the only time I went to a dealer was to buy parts that one can easily get online from dealers everywhere today regardless of their location. Unless you aren't mechanically inclined, with zero tools, you don't need to live next door to a dealer!!!!!!!!!!
The LS dealer was 250 miles from me and delivered the new tractor for free and picked up a couple of older tractors I had, that I didn't like, in trade.
/ Tractor decision #157
LS Tractor parts are made in South Korea. From there, the parts are shipped to the United States and assembled in various warehouses across America.
willy
/ Tractor decision #158
willy
/ Tractor decision #159
Choose the closest tractor dealer around you, you will need help from them in future, so their service is more important than tractor itself.
2025 Tree Boom Mini Skid Steer Attachment (A61572)
2025 Tree Boom...
2015 FREIGHTLINER M2 4X2 S/A 26FT REFRIGERATED BOX TRUCK (A59914)
2015 FREIGHTLINER...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
