/ Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series
#21
We had a TYM dealer on a vacant lot next to a restaurant along the highway back around 2009…I’ve only seen 1 TYM tractor in real life but I was impressed, reading the spec sheet they seem to have much higher capacity hydraulic pump than most other brands.
I have a 2029 LS2025H with only 70hrs. Damn fuel pump solenoid went already to a tune of $578. Like the tractor but it only has 18hp at the PTO. I didn't know that at the time since this is my first tractor. Wish I had 30hp at PTO to run a bigger wood chipper.If you have been following my other thread about the hell we have been in for 7+ months with our T494 you will know why we are now seeking a full refund. Sufficient to say that after sale support from the manufacture and parts are non-existent.
Assuming we are successful our next choice is the MT3 line. the 494 had a 49hp engine, the MT3 offers 4 different HP levels although the lifting capacity for all is the same according to specs.
What has your real world experience been with the HP in your MT3 series and are there any concerns you have had we should be aware of?
I know 1 big difference is the much lower lift height of 96 inches vs the 110 on the T494, but at this point having a tractor with a low lift is better than having a tractor in the shop that you can't ever use.
Our uses for the tractor in order of importance will be:
1. moving brush
2. moving snow with a self contained berco 72 inch snow blower (has its own 33hp vanguard motor)
3. cutting about 1/2 a mile of ditch with sickle mower
4. moving a few round bales from time to time
Thanks.
Even as very happy LS owner I agree with this statement. If I had to rely on dealer support I would not necessarily buy an off brand, dealer support can (and is) all over place in terms of quality and service.I cannot understand a person's thought process when they buy one no-name tractor and it burns them...and then they decide to buy another no-name tractor. You aren't saving money if your tractor is in the shop and they can't fix it and don't want to help you.
Note - coming up on 600 hours on mine.
Even warranty repairs, unless the dealer is willing to transport 100+ miles one way for free. I do have DPF. ECM, Fuel Injection, etc. I had some minor confusion with the DPF but running it harder than I need to has cleared things up. I do have a standard ODB2 interface on my LS and my high end scanner can pull and reset codes, nothing bad but helped my figure out how to keep the DPF and Regens happy. I can operate at 15-1800 to do most things but the tractor is happier at 18-2200 overall doing that work. Just learning curve on my part. My old Kubota just puttered along as needed.I'm assuming you mean you are fixing problems yourself. But if you buy a machine brand new, I would expect the dealer to fix any problems under warranty. I work on everything myself as well - but if its under warranty I'm not fixing it unless its something easy. And sometimes, only the dealer has the tools or diag equipment to fix things. On your LS, does it have a DPF? Having a problem with the DPF or even the common rail fuel injection system would be hard for me to self-diagnose on my Kubota, since I have no means of scanning for trouble codes or reading sensors or actuators.
