Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #1
flyinghigh
century
If you have been following my other thread about the hell we have been in for 7+ months with our T494 you will know why we are now seeking a full refund. Sufficient to say that after sale support from the manufacture and parts are non-existent.
Assuming we are successful our next choice is the MT3 line. the 494 had a 49hp engine, the MT3 offers 4 different HP levels although the lifting capacity for all is the same according to specs.
What has your real world experience been with the HP in your MT3 series and are there any concerns you have had we should be aware of?
I know 1 big difference is the much lower lift height of 96 inches vs the 110 on the T494, but at this point having a tractor with a low lift is better than having a tractor in the shop that you can't ever use.
Our uses for the tractor in order of importance will be:
1. moving brush
2. moving snow with a self contained berco 72 inch snow blower (has its own 33hp vanguard motor)
3. cutting about 1/2 a mile of ditch with sickle mower
4. moving a few round bales from time to time
Thanks.
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #2
I love my LS a lot but if I was in your boat and after my LS dies I will prob be looking at another kubota.
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #3
Seems like you are eyeing a tractor with plenty of size and weight for your listed needs, so that's good.
I seem to be in the minority where my tractor suffers from excessive regeneration cycles, other than that, it has been great.
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #4
I may be wrong, but with these now very complicated emission controlled tractors with sensors and computers..
Spending extra for a "major manufacturers" dealer service and support might not be a foolish thing even without considering the resale value.
If this was pre 2000 it would be a much simpler decision.👍
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #5
The only negatives I considered with the LS were regen cycles (maybe 12-40 hours compared to 200+ with the Branson) and the lower lift height. The only issue I saw in two years of researching was the potential for the LS to go into limp mode for Regen, or for numerous sensors linked to the ECU motor. TYM has the Kukje diesel which doesn't have those electronics.
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #6
Making generalizations is never good, but watching this forum has me worrying about my XG3140 from 2 angles: when are troubles going to start, and how bad will it be when the pollution controls begin to have problems? Mine has about 200 hours on it, so it's practically new and I like it a lot, but the dealer has been pretty indifferent, and part availability during the Plandemic was lousy for the one part I needed.
Repeatedly, others who appear to have lots more experience than I do have said they'll look for a pre-smogged, used tractor. That is not an option for me because I'm all hobby-farmer and not an experienced mechanic (you, too?), but if the EPA can get between you and your work, you might be thinking about buying a fancy yard ornament.
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #7
Coming up on 600 on my XG3135 and nothing serious, just some loose bolts here and there.
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #8
Tough to outline problems you will encounter. Typically all manufacturers have had issues with mandatory EPA added emissions. Newest LS versions are 50 hour cycles depending on use. These tractors don’t like low RPM with emissions that is given fact. Some MT3 have had wrong wiring harness installed from factory however LS stood behind these units buying them back. Turbos on these units are sensitive to cold weather where as you should not run 15-40w diesel oil in colder climates. Other issues have been loss of ground due to corrosion on the connections to the frame. This site is historical book on user’s issues better to do your own research. I own two different models of LS Tractors MT225S and XR3135c both tractors after three plus years have had no major issues rather experienced issues with MMM deck wheels I reengineered with bearings for better swiveling. I too had same issues on what to purchase next. I had came from both Kioti and Kubota smaller units they to were just as equal in reliability than the LS tractors I own Today. Yes every once in awhile someone gets a lemon it’s the dealer and manufacturer that makes the difference on correcting the situation. Study this site and draw your own conclusions.
Study shows more regen issue threads (LS says every 2 hours is normal is one heck of a read) than I feel comfortable with. We are in very cold weather so that turbo sensitivity is a big thing.
one of the big things on the 494 was the ability to easily bypass all the regen system and no sensors or turbo to deal with...sigh...might have to suck it up and just wait for the part...but maybe our lawyer can help incentive them to make it a priority.
Thanks for all these comments...a used older tractor is looking like the best option if we have to start over.
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #10
You have to remember that this is not a part for this tractor. It is an alternate part, so not something they would have in stock.
Iowa dealer should have replaced the unit. If this was really a design issue, all of us with that unit would be having problems. It is frustrating, but not so much an oem problem as a bad dealer (1st one) problem.
Not sure what you mean when you say it is not a part for the tractor
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #14
What you said before is this is something with ears, not what comes on the tractor. It is an alternate part. If it is just the standard part, then the dealer should 100% take one off of a unit in stock.
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #15
"Dealer advised that there is a new "heavy duty" front hub assembly that now includes the "heavy duty" C Clips..."
The point being this part was not a stock part for your unit and if new, would not be in the supply chain in quantity because failure rates are not high.
Again, it really sucks this happened to you. I feel partly responsible. I still see the root problem being the Iowa dealer.
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #16
I have an LS MT250, 2 1/2 years with 178 hrs.and very satisfied with it.
You have already found that dealer support is a make it or break it decision, my dealer is only 25 miles down the road and easy to work with.
If there was not a local (under 50 miles) LS dealer I would have made a different decision we have 3 JD dealers inside 30 miles. The price difference for a JD was a deal breaker.
I see the confusion. My initial concern was the banging in the front end. Then I found the FB article about the snap rings in both front hubs that had "ears" that were defective and had been replaced by a newer version.
When the 2nd dealer tore our front end apart they found metal shavings everywhere throughout the axle. They also found the metal in the front left hub extremely thin with a jagged hole in it:
This is the part we are waiting on now. Not your fault Torvy, you and others gave the best personnel experience information you had. I am concerned that all of us are driving around with thin walled hubs like this one, but even if they fail I don't think they will cause the loss of the wheel like the clips would...fwiw, this tractor DID have the new clips vs the old "dog eared" ones so TYM has already corrected that problem in newer builds.
To your point, I guess it is good they don't have the part in stock because maybe the failure rate is not high...but 6-7 months is still too long for any part IMHO...my berco dealer had to wait that long for the foward/reverse switch for his big 5 series TYM last year.
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #19
What is a TMY?
   / Working toward refund from TMY, hoping to move to LS...question on which HP and any concerns about your MT series #20
What is a TMY?
TYM? I searched "tmy tractor" and got returns for TYM. I swap letters when I type (I'm not dislexkik, I sware), so that's what I thought he meant.
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
2023 CATERPILLAR 120 MOTORGRADER (A60429)
2023 CATERPILLAR...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
