House Build 2023
/ House Build 2023
The driveway and sidewalks are formed up. I trenched under the driveway by the house and added a 4" pipe just in case i need to go under the drive with power or water at some point in the future. Going to do the same with the sidewalk at the house. Also adding a pipe at the bottom down from the shop just in case i need it for drainage.
20231223_102454.jpg20231223_085532.jpg20231222_083624.jpg20231222_083605.jpg20231221_170145.jpg
/ House Build 2023
The wife and I pulled wire to the shop yesterday and got the panel ready to go. Also threw a pic in of the garage door in the shop. I had them do a 4' high lift so the door will hug the cieling as close as possible. It will have a shaft drive motor on it next week.
/ House Build 2023 #304
Nothing scares me more in concrete work then seeing wire laying on the dirt. The biggest lie told over and over again is that they will lift it will spreading and leveling the concrete. Even bigger lie is that it will stay in the middle of the concrete while they walk on it. If a concrete contractor doesn't use rebar on chairs, they should be fired before the cement trucks show up. My only exception is that wire is OK in walkways because you can actually lift it and work it without stepping on it, and it will remain in the middle of the concrete.
/ House Build 2023 #308
And I pretty much disagree, but we've been over this before.
/ House Build 2023
I can put as much rebar as I want. I've got a handful of sticks left from footers that i will use around the perimeter and in front of the doors. The issue is the expense. I'm already paying a pretty penny. Enough wire for the whole thing is WAY less than #4 rebar. I'm wanting to say 40-60 sticks of rebar was more expensive than 2500 sqft of wire.
I have a very solid base of compacted shale. I understand the risks as they have been laid out above and agree that rebar on chairs would be the best case. I've seen lots of this finishers work and feel it's with the risk.
We don't have any frost heave, I've got good drainage and a solid base.
/ House Build 2023 #310
Wire and rebar do not make the concrete stronger. It holds it together when it cracks. If they have a really good slump when they pour the concrete, odds increase dramatically that you will have very minor cracking. All concrete cracks, that's a given. The wetter the concrete, the more it will crack. There is a point where it's too dry and they cannot spread it, but that's almost impossible with cement trucks. The only way to stop them from adding water and making it into soup is to stand there and tell them how important the slump is to you. They know, but they don't want to spread it without extra water. All the water does is make it easier for them to spread it. Easy means faster. They get done sooner, get paid the same amount, and have an easier day.
The big advantage rebar has over wire is that it is held up in the air with chairs, and the concrete completely surrounds it. If it was possible to lift the wire and for it to remain in the middle of the concrete while everyone is walking on it, wire would be better then rebar. What usually happens is they start the pour and a guy will lift the wire while the other guys are spreading it. Then two guys will grab a screed board and start leveling the concrete while just one or two are spreading it. The guy doing the lifting gives up on that and will start spreading because they don't have time to pretend to lift the wire when it just ends up in the dirt while they walk on it. You get some pictures of them lifting it, but before it's halfway done, that isn't happening any more.
100% of every house that I've worked on with wire in the slab, and cut through the concrete to move drain lines, has had the wire on the dirt. In the last 20 years, that's probably been close to 50 houses, or more. Wire is very common in older homes around here. It was an idea that was tried, and failed. Now it's not allowed anymore. It's just not possible to keep the wire in the middle of the slab.
/ House Build 2023
The girls' bathroom is about done! Also got the house trailer sold today! Really nice couple came by and gave a deposit. No problem with us staying until the house is ready and knows it needs to move quick when we get out. It's gotta be off the property before we can close on the mortgage.
/ House Build 2023 #316
Those beams really set off the wood on you ceiling!!! Very nice.
How high up is your fan? On the box, there should be a diagram showing where the fan needs to be from the floor to be effective. Too high and you don't get any air movement.
/ House Build 2023
The fan is REALLY high. The peak of the vault is about 22'. I got the biggest fan that I could fit between the trusses for a reasonable price. It's 80" dia. It only came with a 2' down rod so I had the center beam made 10"x10" so it would get the blades far enough down to clear the vault by about 8". I would have liked to have a bigger one farther down but this one was the best I could do without having to spend upwards of $2,000. It's supposed to move almost 10,000 CFM of air. I'm hoping it's enough to keep the air stirred up so I don't have hot and cold layers.
/ House Build 2023
Now that we are getting real close, we may be able to move in by the end of next week (yay!). Please give me some pointers of what I need to check for my own personal "inspection". It should be inspected by a pro but I want to double check to keep them honest. I'm going to grab a GFCI recep tester and check receps, but I don't know which ones should be protected by GFCI. I know the ones outside and near water, but I don't know more than that. I've been eyeballing as much as I can through the whole process and it's all coming together now. I don't know what to look for on the plumbing side either aside from making sure the water comes out and goes down the drain.
What would you check on a finished house?
/ House Build 2023 #319
In my opinion, Code has gone crazy with GFCI outlets. In every new house that I've worked on, there is a dozen or more GFCI outlets next to the breaker panel on the garage wall. It's easier and cheaper for the electricians to install them there, and then from the garage, they run their lines to where Code says they have to be. Kitchen, bathrooms, laundry room, porches and sometimes pantries. That's just off the top of my head. Easiest way that I've found to check outlets is to use an outlet socket adapter. Plug it in and see if the light goes on or stays off. I use them for turning off breakers too. Just plug it into the outlet and start turning off breakers until the light goes out.
The GFCI is first in line. All outlets after it on that line are protected. Turn off the GFCI, then you can use the outlet socket adapter to see which outlets are affected. In kitchens, it could be three or four different lines.
/ House Build 2023
My panel has GFCI breakers in it. So none of the receps have the test buttons, same process though.
Anything else I need to be looking for other than just obvious stuff missing or not functional? Electrical or otherwise.
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
Frontier Forks (A64126)
Frontier Forks...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
