Buggs67
These connectors are on sale right now at Amazon. https://www.amazon.com/dp/B07T1HYJ9G/ref=twister_B08HLLPW6V?_encoding=UTF8&th=1
Most of these are not crimp but solder and shrink with a heat gun. Works well but really hard if you get lazy and try a lighter....Coworker ordered a couple kits of butt splices from Amazon for our work trucks.
To tell you the truth, I was disappointed. The kit seemed really nice. But the metal they use is way too soft so the crimp is extremely weak.
Is there any flux included in these? The completed solder joint looked like a bad solder joint, like no flux was used in the connection. There were strands of wire that didn't have any solder on them.
I bought a set of these butt splice waterproof connectors. The metal alloy used of course melts at a very low temperature. As near as I can tell there is no flux. Anyway, before trusting the connectors I tested them. If CLEAN copper wire is used then the alloy wets the wire just fine and the joint is mechanically sound. Oxidized copper wire WILL NOT be wetted and the joint will fail. For making up butt splices with clean wire when all you have is a heat gun or similar these connectors seem to be fine. I will be using them for some joints.Is there any flux included in these? The completed solder joint looked like a bad solder joint, like no flux was used in the connection. There were strands of wire that didn't have any solder on them.
Your just assuming. The kits we have are crimp with heat shrink on the ends. Not a solder connection.Most of these are not crimp but solder and shrink with a heat gun. Works well but really hard if you get lazy and try a lighter....
Soft metal inside is just a tin solder not crimp sleeve.
True and why I said "most", as usual the assume rule is true for me.Your just assuming. The kits we have are crimp with heat shrink on the ends. Not a solder connection.
I posted because his link above said "Waterproof Solderless" was the same kits my coworker purchased for the work trucks.True and why I said "most", as usual the assume rule is true for me.![]()
| Color | RED BLUE YELLOW WHITE |
| Gauge | 10,12,14,16,18,20,22,24,26 |
| Connector Type | Solder |
| Contact Material | Tin |
| Insulation Material | Polyethylene |
I use these connectors and I agree about the weak crimp. This can be minimized if the shrink bonds correctly with the wire insulation but this doesn't always happen.Coworker ordered a couple kits of butt splices from Amazon for our work trucks.
my youtube video above demonstrates theseI use these connectors and I agree about the weak crimp. This can be minimized if the shrink bonds correctly with the wire insulation but this doesn't always happen.
The product I received does not solder and needs to be crimped. This may be the reason it is on sale.
There is a newer version available:
A good crimp tool is also a must have.I use these connectors and I agree about the weak crimp. This can be minimized if the shrink bonds correctly with the wire insulation but this doesn't always happen.
