Ck2610
/ Ck2610 #1
4020tanner!
Teutopolis
Ck20s
Ok so I got question so I notice to when I had the tractor wide open no load . Rpm over 3k I had little puff of blue smoke. The tractor is turned up around in half. Oil good on safe mark . I normally don't run wide open with no load but today I did. Long I don't max out rpm I never see blue smoke. Even under heavy load no blue smoke. Any idea why
/ Ck2610
I might add the oil level is just little bit over full. In the tractor is turn up a around and a half
/ Ck2610 #4
"In the tractor is turn up a around and a half"
???? What are you trying to say?
/ Ck2610 #5
It's a manual just adjustment of fuel supply. You can theoretically turn the non epa 25hp upto somewhere around 33hp, by removing a crimped cover, and adjusting the screw
Some people say you can get upto 40hp with no ill effect, but im not 100% sure on that
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
2000 Ford F-350 Pickup Truck, VIN # 1FTSX30F3YEB26863 (A65563)
2000 Ford F-350...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2016 Volvo Semi Truck (A66285)
2016 Volvo Semi...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
