Ck2610
/ Ck2610 #1
4020tanner!
Teutopolis
Ck20s
Ok so I got question so I notice to when I had the tractor wide open no load . Rpm over 3k I had little puff of blue smoke. The tractor is turned up around in half. Oil good on safe mark . I normally don't run wide open with no load but today I did. Long I don't max out rpm I never see blue smoke. Even under heavy load no blue smoke. Any idea why
/ Ck2610
I might add the oil level is just little bit over full. In the tractor is turn up a around and a half
/ Ck2610 #4
"In the tractor is turn up a around and a half"
???? What are you trying to say?
/ Ck2610 #5
It's a manual just adjustment of fuel supply. You can theoretically turn the non epa 25hp upto somewhere around 33hp, by removing a crimped cover, and adjusting the screw
Some people say you can get upto 40hp with no ill effect, but im not 100% sure on that
PATRIOT 5100 ELECTRIC CAKE FEEDER (A64277)
PATRIOT 5100...
White Oak Boards (A65640)
White Oak Boards...
2019 Chevrolet Tahoe (A64194)
2019 Chevrolet...
Schaben Pull-Type Sprayer (A66285)
Schaben Pull-Type...
Ford 3 Point Bucket Scoop (A62613)
Ford 3 Point...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
