Stuck loader fitting - how to loosen
/ Stuck loader fitting - how to loosen #1
SouthernSky
Deville, LA
2013 Kubota L3200DT
I have to rebuild my bucket curl cylinders due to leaks. Of the eight connections I have to remove to also change four hoses, one is stuck.
The 7/8" wrench pictured is just there to keep me from twisting the tubing while trying to figure out how to loosen the fitting.
I've tried a soaking with PBBlaster and putting both a 7/8" and 11/16" wrench on the two nuts and trying to pull them together.
I tried a rubber mallet which had no impact on loosening the fitting in the lower yellow area.
I sure would appreciate any guidance on how to get this off while still on the tractor.
/ Stuck loader fitting - how to loosen #2
Those look like swivel connections but possible someone over torqued or added locktite. Maybe a little heat but have to be careful to not burn the oil.
Going out to try both ideas now ...
Well, both worked. I'm not sure which one. I tapped it with a ball peen hammer and then heated it up for no more than 15 seconds and I was able to get it off.
Unlike the seven others, it turns out this has rust on it which explains a lot.
I couldn't afford to break that aluminum tubing so, as always, thank you!!
/ Stuck loader fitting - how to loosen #6
That's not aluminum tubing, its steel. That dry ring of rust is also why putting oil on it wasn't going to work. Wack it with a hammer or as a last resort heat it.
/ Stuck loader fitting - how to loosen #7
I realize this job has been completed but for future reference or anyone else reading an air hammer works wonders for loosening stuck or difficult to reach fittings. It also doesn’t pose much risk of twisting off the opposing fitting like cranking on it with wrench does.
/ Stuck loader fitting - how to loosen #8
Darn, there goes another potential epic thread down the drain because it was solved too soon.
I was going to suggest Kroil oil, then maybe heat.
Well, in that case, how would you remove the rust from the fitting?
/ Stuck loader fitting - how to loosen #10
When hammering on something like that using a backup hammer may be a good idea.
/ Stuck loader fitting - how to loosen #11
Plug the hole with something like a piece of cloth and use Scotchbrite first. If that doesn't clean it use some emery cloth.
/ Stuck loader fitting - how to loosen #12
I have just used a wire brush to clean the rusted male JIC fitting. Dont go to aggressive as the chamfered edge is the seal.
/ Stuck loader fitting - how to loosen #14
If you have a next time hold the lower nut and try to loosen the top nut in your highlighted post. If you have a Dremel tool insert a home made from a wooden stick, wooden peg in the opening at the top and clean away with the Dremel round wire brush wheel. Or use a wire brush wheel made for a electric drill.
A word of caution to those thinking heat. Be very careful about using open flame heat around hydraulic oil.
"Hydraulic and lubricating fluids are relatively non-flammable in bulk, but they can be flammable or explosive when atomized."
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2006 HEIL MC407 (A67714)
2006 HEIL MC407...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
2020 ISUZU NRR BOX TRUCK (A67714)
2020 ISUZU NRR BOX...
CAT D9G Springs (2) (A68134)
CAT D9G Springs...
2019 Ford F-550 4x4 Venturo HT40K-X 6,000 lb. Crane Service Truck (A66736)
2019 Ford F-550...
