How do I protect rain gutters from ice damage?
/ How do I protect rain gutters from ice damage? #21
Hmmm, how to keep gutters from freezing? Move to Florida?
David from jax
Every once in a while it snows in parts of Florida.
Although, perhaps wind and rain storms are more of a problem down there.
/ How do I protect rain gutters from ice damage? #22
"Snow" in Florida is not even considered as a real snowfall by people in most other places who get enough snow to own snow moving equipment! The only reason I have snow moving equipment is because I bought it to move dirt and none of it has ever moved snow!
David from jax
/ How do I protect rain gutters from ice damage? #23
Commercial metal buildings often have those dams installed -I always assumed there was a liability issue with the snow shedding injuring someone.
What about the kind of louvered dispersal things look like miniblinds? Not sure how they would take snow but they are supposed to keep the runoff from falling straight down and eroding your concrete
Fair enough, but that's also what the gutters do. Except when they get torn apart by ice and snow, which I am trying to prevent. 😀
/ How do I protect rain gutters from ice damage? #25
10 years ago, my Morton Buildings sales rep said they want the snow to get off the roof quickly. So no slide stops are recommended.
But I see a few newer buildings with snow blockers. Maybe something changed.
When the snow slides, it makes enough noise - it's a warning to step a little faster out of the way. :)
If a building is built correctly for the snow load in the region where it stands, the snow does not need to slide off. That said, many incorrectly or poorly built buildings are still standing because metal roofing and/or poor insulation prevents the snow from building up too much.
/ How do I protect rain gutters from ice damage? #26
Thanks, but I think I will stick with the Morton Buildings recommendation. They have been around for a long time.
/ How do I protect rain gutters from ice damage? #28
On any roof with exposed fasteners, the longer the snow stays on, the higher the chance of a water leak as it melts.
/ How do I protect rain gutters from ice damage? #29
That's a whole different subject, of course.
Anyway..... OP, how far does the metal on your roof extend past the eave and what is your roof pitch? If the metal extends a couple inches at least and if the pitch isn't too steep and/or the gutters too wide, you can get the snow to go out over the top of them by mounting the gutters 1-3" lower than "normal".
/ How do I protect rain gutters from ice damage? #30
i use raychem heat tape on my buildings. it loops up 2 feet above the gutters, and runs thru gutters and downspouts. i even run it thru underground drain pipes. this is self regulating tape, so it only runs when needed to melt ice. its self regulating.
/ How do I protect rain gutters from ice damage? #32
Something to consider regarding the use of heat tape.
That was my only concern.
I misunderstood. I thought the concern was about roof collapse.
/ How do I protect rain gutters from ice damage? #33
Regarding the use of heat tape. In most parts of the country, the most likely reason for loss of grid power and therefore shutdown of heat tape, is snow or ice storms.... Just something to consider.
/ How do I protect rain gutters from ice damage? #34
well, my house is on a whole house generator backup....
/ How do I protect rain gutters from ice damage? #35
Certainly worthwhile. Just wanted to throw out the idea for the OP to consider. If a person plans to rely on a generator for such things, they should definitely do a few practice runs ahead of time to make sure it all works. I live off grid and do construction for many people who are also off grid, so figuring out the most efficient ways to use (or not use) electricity is something I deal with a lot.
/ How do I protect rain gutters from ice damage? #36
Probably shouldn't be too much of a concern. When the power comes back on the heat tape will do its thing again. A few hours or even a couple days shouldn't hurt the gutters.
/ How do I protect rain gutters from ice damage? #37
I just ordered a set of heated steps pads , 10” x 30” plus a 3’ x 5’ heat mat for my front steps. Sick and tired of shoveling steps.
It extends about 3 feet past the exterior wall, 4 in 12 pitch. The building sales person talked me into that configuration to make it more fit in with a "high end residential rural area" and I agree. I regret that decision to this day, for this issue and more.
My building is properly engineered for snow load for the area. And after LAST year, I know I am safe. We have an unbelievable winter that will likely never recur in my lifetime. 😀
I do like this Raychem product as it increases output/heat as the temperature continues to drop further .....
2025 Swict 84in. Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
Decorative Pelican Statue (A61574)
Decorative Pelican...
UNUSED X-STAR GRAVEL LEVELER (A64280)
UNUSED X-STAR...
2010 New Holland Boomer 8N (A62613)
2010 New Holland...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
