Finish Mower Replacement wheels
/ Finish Mower Replacement wheels #1
40_acre_mule
South Mississippi
Kubota L4701
I bought a Land Pride Finish mower FDR 1672 back in 2005. Served me well even though I was a little rough on it as I developed my property.
In 14 years, I think I only bent two wheel yokes (able to press them straight), and never replaced a wheel.
I let it go when I sold the old Kubota in 2019, but immediately replaced it. The areas I'm mowing are finished up now and far easier on the machine.
Now, in only four years, I've bent three yokes and just busted a wheel. These assemblies seem to be made from much more inferior materials then before.
I don't want to just get the same old cheap stuff.
Can any of y'all recommend a more robust yoke/wheel with which to replace them?
It has a 1 inch shaft.
/ Finish Mower Replacement wheels #2
You don't say what brand the mower is. I've owned 3 finish mowers since 2000 of various different sizes from 8' to 21' and one thing I can say is I've never bent or destroyed a yoke or wheel. What are you doing to tear them up?
/ Finish Mower Replacement wheels #3
I have posted this company before. Ordered from them twice with quality products arriving. The rubber tires were even better the second time I ordered.
/ Finish Mower Replacement wheels #4
/ Finish Mower Replacement wheels #5
Bending the stem of the yokes was the one weak link on RFM's for me. Been using RFM's since 1991 - a couple LandPrides and a few Caronis. All had what appeared to be the same yokes and wheels. I did buy a couple wheels from Agrisupply over the years, but no yokes. I bought one new 5' Caroni back in '91 and two fixer-uppers (5' and 7-1/2'). I used two 5 footers to make one good 5' deck for the Ford. They have common parts so that gave me some extras pieces. There are wheels with either roller or needle bearings available through different sources.
I made a steel device to straighten the stems of the yokes using a hydraulic jack. Earlier this Fall, I replaced the factory wheel supports on my 7-1/2' Caroni with a homebrew one. The factory support had large upward offsets at the ends that required most of the spacer bushings to be installed between the wheel and the support. With that much leverage I managed to bend the yoke shafts occasionally when swinging the deck over the edge of the driveway or a big root.
The homebrew support is a lot closer to the ground and requires no spacers to achieve the desired cut height. So far it's been working very well.
Sorry, thought it was clear that I replaced the Land Pride with another Land Pride, same model (14 years apart).
I am not doing anything different, just mowing the same areas I've been mowing for years. It is all smoother than when I started all those years ago. Still scraping the same occasional tree root and bumping the edge of the paved portion of the driveway. I think the yokes might be bending when I back up for some reason. I've pressed a couple straight again, but the metal seems softer or more pliable than the old ones. I don't have any idea how the wheel split. The other wheels are chipping pieces off, not just wearing down.
I am hoping some other brand has a stronger built yoke with the same shaft dimensions and some better wheels, too.
/ Finish Mower Replacement wheels #7
I have a similar setup and problem. I had a LP 1660 purchase 10 years ago and never bent a yoke. I have a LP 1672 bought a couple of years ago and currently have two bent yokes. I am looking for the same solution.
(Complaining ahead)...
One of the things that bugs me is that Land Pride has a nice pretty sticker that says "Made in the USA"
When I see that, I expect American quality (another time for discussion of the work ethic of Gen Zers).
But, I'm guessing the fine print says "from domestic and imported parts".
I want strong American steel, not cheap chinese stuff.
Complaining over
Thanks to those that replied. I will look into this High Grade Manufacturing
Photos
/ Finish Mower Replacement wheels #13
Caster wheels were the weak link on several rear finish mowers. Rough service on hillside farm with a lot of back and forth, roots, rocks, trees, etc.
Eventually replaced the 1” spindles with 3500# trailer axles and hubs. Been trouble free for over 10 years.
/ Finish Mower Replacement wheels #14
I guess you can use your finish mower to bush hog with if you want to but they aren't made for that rough cutting. Rough use is the issue, not the wheels.
/ Finish Mower Replacement wheels #15
Our mowing requires a lot of forward and backing. Puts a lot of stress and wear on the spindles. Coupled with 4x4, sharp turning little tractor is best platform for maintaining our many yards. The Woods RD7200 is 24 years old. Sees about 80-100 hours of use per year. Trailer hubs and axles are much stronger and far cheaper than OEM replacement parts. Even with frequent greasing the OEM spindles and spindle bushings wear out quickly. Slop puts added stress when turning increases risk of bending. Saved almost enough to purchase a Hypertherm plasma cutter used on this one modification. Made fabrication super easy and somewhat fun.
I honestly don't recall hitting anything. It could even have gotten bent after the tire cracked and came off.
I was not mowing anything out of the ordinary, on smooth, level ground. And the front tire never really comes into contact with anything other than a surface tree root, but i wasn't even close to those. I was doing the occasional 2 or 3 point turns.
/ Finish Mower Replacement wheels #17
It may not be the yokes that are the problem, but that the receiver angle is. Should be absolutely vertical for proper reversing caster action. Otherwise , it can stall in the angle that produces the net vertical receiver angle. Even front to rear angles will/can throw it off. Yes, I know that the blades cut better with a rearward slope, but I'm not bending any yokes on my 4' deck F525, 78" F935, 72" F1435, 84" Woods 7', or my 6' brush cutter, and I jump 6" curbs with them. Sparks but no bends.
I also see a lot of mowers now with cheaper treaded gauge tires. Believe me you want slicks because the 'scrub torque' generated by reversing the caster wheel, is lowest. You want that wheel to swivel as fast as possible (and not tear up the lawn, btw).
/ Finish Mower Replacement wheels #18
From the time I first used a rear mount mower I have always slightly raised the deck when backing up to take the load off of the rear wheels / spindles. Never had a problem until last season I did slightly bend a rear spindle (mount) when backing over a small stream and into the far bank. As mentioned in the above post, the bad angle now is putting a lot of stress on the spindle and wheel when turning.
/ Finish Mower Replacement wheels #19
Have you tried Harbor Freight to; see if they
have anything you can use?
willy
/ Finish Mower Replacement wheels #20
Here’s my solution to the problem. I bought some man lift tires on eBa, I think they will out last me.
