Putting a drain pipe through a retaining wall
/ Putting a drain pipe through a retaining wall #21
I built one small wall using fabric. Then I saw a video by a landscape contractor vehemently criticizing the use of fabric. It got be to rethinking the use on my second larger walls. I think landscape fabric is designed to lay on top of the dirt and let water through. If it is under the dirt I think it might clog up and act as a barrier and not pass any water.
And that is the problem with the internet. You can find someone to justify whatever you decide to do.
On my second wall, no landscape fabric, back filled with 2 feet of gravel, sock covered pipe at the bottom, several levels of geo grid. After a rain I evidence of water weeping out of all levels of the wall. I think that is a good thing, to me it means the water is not trapped behind the wall.
Doug in SW IA
Its opinionated driven... for disclosure I have a civil engineering background but it doesn't mean I am 100% right and it's not because he is a contractor that he is ether. If you notice in my illustration above the top is seal with clay to minimize water coming from the surface. The concern is ground water and water fallowing the wall and going under, I would argue that if the soil clog the fabric it will clog the pure stone and the pipe as well so the longer I can keep that clear the better it is... I didn't show it but the fabric should go down along the undisturbed soil (left looking at the picture) and the pure stone and up the wall to separate the stone from any fines. some pipe comes with a filtration sock on it but I usually still put fabric to separate fines and pure stone. Water eventually make it through any soil the one it has the hardest time going through is clay.
You can get away without fabric, not saying it's a must but to say its a bad idea I disagree... If doing it without fabric I would used screen sand (coarse beach sand) to make the separation around the pure stone. or simply pipe with filtration sock and sand around it. But I like using pure stone it had a lot of void and flow capacity if the pipe get clog and less chance for it to clog.
/ Putting a drain pipe through a retaining wall #22
You want the water to run away from the wall and a place for the water to flow too, the illustration is how I would personally do it, now I am not sure if you want pure stone below the .
two slightly different things for me. I run the filter fabric vertically against the native soil, add gravel and pipe then pull fabric over to wall. On the drains, I install 2-45 with a short section instead of 90’s. This makes life way easier if you ever have to snake it out.
/ Putting a drain pipe through a retaining wall #23
definitely a good way of doing it for the fabric and also the way I would do it... I forgot to show it in the drawing
  • Good Post
Reactions: D&D
Q- is there any way to bend the rigid white perforated 4" drain pipe? Maybe heat it up a little?
I know there is corrugated black perforated drain pipe that is flexible. But I have heard it is subject to collapse and the corrugations cause sediment retention and buildup.
/ Putting a drain pipe through a retaining wall #25
yes , you can. filling the pipe with sand and then heating is preferred to keep the pipe from kinking. Swimming pool and pond guys use a flexible pvc. You might consider going to a 3” drain depending on wall height.
That looks very flexible but does not appear perforated. Yes I am thinking of scaling back to 3" as my wall is only 100' long and while I expect run off, hopefully nothing that would exceed 3".
I am going to run a solid 4" pipe from the lowest point of the wall, perpendicular, under the wall, to daylight.
Where that "daylight" drain pipe emerges behind the retaining wall, I need to turn 90 degrees so it follows the wall, then add drain piping behind the rear of the wall. I have two separate thoughts:
1. Put an initial single section of somewhat rigid 4" perforated drain pipe behind the wall, connecting to the drain pipe that goes to daylight. This section would be at the lowest part of the wall, presumably handling the most water.
2. "Upstream" from that, "neck down" to use flexible perforated 3" drain pipe. Connect them together by simply shoving some number of feet of the 3" flex line into the 4" rigid perforated pipe.
This method of connection might sound funky but my excavator says he does it a lot. Having looked again at the open trench, there is not a lot of extra room from side to side, so I think 3" is a better fit for the majority of the run.
I am considering this for the 3" drain pipe:
/ Putting a drain pipe through a retaining wall #27
That is what I consider best practice for this too.
For bending PVC, a heat gun or a propane torch works. Keep it moving all around and when it starts to get soft stop quickly or you will have a pile of goo.
/ Putting a drain pipe through a retaining wall #28
electriCal contractors have heat box for softening conduit to bend it
/ Putting a drain pipe through a retaining wall #29
Yes there are tools made for this job, and you MIGHT be able to rent one but otherwise they are hella expensive, especially for a one-time use. I have seen versions that are heat blankets, too. But for a one-time deal, heat gun or torch and some care will do the job, just not as easily.
/ Putting a drain pipe through a retaining wall #30
For 90 degree bends on large diameter PVC I don't mess with trying to make them. I buy preformed Sweep Ls or Combination Ts at Home Depot. I prefer the T shape - also sometimes called cleanout hubs - you can use them as a 90 by plugging one end. If you plug the end with a threaded PVC connection in similar large diameter, that gives you a way to root or flush out the drain pipe if you ever need to do so.
Instead of the slotted corrugated drain I use rigid PVC drain pipe with the drilled holes. Put down geotextile into the ditch, then some clean gravel, and then the PVC. Fold the geotextile over the PVC and backfill..... that way makes a better drain.
rScotty
/ Putting a drain pipe through a retaining wall #31
I like the contractor's thoughts but would upgrade the pipes under the wall to pipe material that can withstand some weight and movement. Nobody can forecast what the settlement and movement is going to be when clay is involved, but the pipe needs to take all the weight if necessary. 4" iron is a common for municipal water & sewer pipe - which keeps the price reasonable. Get ductile iron if you can and cast iron second choice. For as little amount as you are looking for I would see who local stocks overage from projects. Ask at the water utility. There are also decent heavy wall PVC for that matter - but not at Lowes/HD.
About the sock, we had a flood here & rebuit some perf drainage with some left bare, some socked, and some with double sock and PVC peanuts. Some silted up and some hasn't yet. My latest effort is to lne the bottom of the ditch with strips of geotextile 3 or 4 foot wide, put down an inch of washed gravel, then the perf pipe, then cover the pipe completely with gravel and fold the sides of the geotextile fabric over it all and backfil.
That system worked until the willow roots from the windbreak found their way into the end of it.... Now I have to roto-root my drain pipe every year.
So my last piece of advice is whatever you do, make it "roto-rootable". If 300 ft long consider putting in a pair of back to back risers for access to the pipe every 100 feet
luck,
rScotty
Some copper sulfate strategically placed will repel roots.
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A61165)
2008 Kawasaki...
2004 Mack CL713 Tri-Axle Heavy Haul Truck, VIN # 1M1AD64Y04M001417 (A61165)
2004 Mack CL713...
2021 John Deere 1775NT Planter (A63109)
2021 John Deere...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
(INOP) 2019 KUBOTA KX040-4 EXCAVATOR (A62129)
(INOP) 2019 KUBOTA...
