plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 4,055
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I'm building a retaining wall using stacking stones (not the kind with a lip in back.) It's kind of a lazy quarter-circle shape, slowly descending, about 100 ft long, with a gentle slope behind it.
I have excavated a trench about 2 ft wide and roughly a foot deep-- for 6" of compacted type 2 road base, then the first course of stones below grade. The top of the first course of stones should be roughly at the current grade. As my wall goes up I am planning to backfill with 3/4" clean gravel. I am undecided yet on whether to put a pipe on the back side of the wall, or whether to use fabric if I do add such a pipe. I am wondering if the gravel and natural slope will provide the drainage I need.
My concern is trapping water behind the wall. I need to get from behind the wall to daylight. I want to somehow pipe from behind the wall, through the wall, under a gravel driveway, then to daylight. I am not sure the best way to do that?
Should the bottom of my drain pipe (behind the wall) be at the same grade as the bottom of the first stone? Both would be sitting atop compacted road base. If so, this means the pipe needs to go through the wall and I am not sure how best to do that, such as cutting stone blocks. Or should I have my drain pipe even farther below grade, with the pipe embedded in the compacted base (or perhaps in embedded adjacent gravel instead) so the top of the drain pipe is roughly equivalent to the bottom of the first course of stones?
Regarding piping, I am guessing SDR 35 4" pipe is a good choice once I am outside the wall and to take it (underground) across the gravel driveway. But what about a pipe behind the wall to connect to the SDR 35? I have heard horror stories about the 4" black corrugated drain pipe collapsing or getting plugged.
Any suggestions?
Any suggestions?
