2019 ford ranger review....
/ 2019 ford ranger review.... #931
I'd lay odds on a blend door actuator. Could be bad or disconnected or loose. Must be a reason it works at full cold, but I don't know the specifics of this model as of yet (and I hope to not have to learn them on mine...)
On some vehicles they are vacuum actuated so it could be a leaking hose.
/ 2019 ford ranger review.... #932
A little more experimenting today heat comes out passenger side dash vents until it's set below 64˚.
Getting this warning when we get in da truck.. Time for a new battery? Anyone else see this?
/ 2019 ford ranger review.... #935
Getting this warning when we get in da truck.. Time for a new battery? Anyone else see this?View attachment 832035
I see this on my hybrid car sometimes when I park it at a point the battery is low on charge. I would suggest just giving the battery a good slow charge. Cars have so much electrical load now that if you don't drive long distances at speed, the battery doesn't get fully charged. I charge my F150 every six months or so and it takes quite a while to slow charge fully. It also usually hasn't gone into start/stop mode for the last few years, probably because the battery isn't sensed as fully charged. The truck and battery are about 7 years old. Don't panic. :)
/ 2019 ford ranger review.... #936
What year vehicle? If the battery is over 3 years old and you drive the truck frequently, then yes, the battery could be starting to fail.
Our F350 sometimes sits in the garage for 2-3 weeks unused and I started getting the notice on my phone in the FordPass App "Remote features disabled to preserve battery" around 3 years of age eventually one of them lost a cell and had to be replaced.
However, I have also received the same notice after the truck sat for 3-4 weeks unused and the truck batteries were on a battery tender and it indicated fully charged.
Its a 19 and has 50K miles on it. Seems it might be a agm in it.
/ 2019 ford ranger review.... #938
..It also usually hasn't gone into start/stop mode for the last few years, probably because the battery isn't sensed as fully charged. The truck and battery are about 7 years old. Don't panic. :)
That is one of the criteria that will prevent stop/start mode from working so yeah, you probably have a battery failure looming.
/ 2019 ford ranger review.... #939
Hmmm, Our F350 is a 2019 as well, purchased in June and batteries had to be replaced 5/2023, right at 4 years.
/ 2019 ford ranger review.... #940
True, but it seems to be looming very slowly. It's been going on for about three years now.
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
Deere 35P (A53317)
Deere 35P (A53317)
2014 JOHN DEERE 35G EXCAVATOR (A62129)
2014 JOHN DEERE...
CFG Industrial MX12RX (A60463)
CFG Industrial...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
